Ir para o conteúdo principal
How to Fix Joy-Con Drift Without Disassembly
O que você precisa
  1. How to Fix Joy-Con Drift Without Disassembly, How to Fix Joy-Con Drift Without Disassembly: passo 1, imagem 1 %32 How to Fix Joy-Con Drift Without Disassembly, How to Fix Joy-Con Drift Without Disassembly: passo 1, imagem 2 %32
    • Press and hold the black round button on the back of the Joy-Con, then slide it forward to remove.
    Pergunte ao FixBot
    Comentar
  2. How to Fix Joy-Con Drift Without Disassembly: passo 2, imagem 1 %32 How to Fix Joy-Con Drift Without Disassembly: passo 2, imagem 2 %32
    • Open the 404B contact cleaner and insert the tube into the nozzle.
    Pergunte ao FixBot
    Comentar
  3. How to Fix Joy-Con Drift Without Disassembly: passo 3, imagem 1 %32
    • Push the Joy Stick to the side and hold.
    Pergunte ao FixBot
    Comentar
  4. How to Fix Joy-Con Drift Without Disassembly: passo 4, imagem 1 %32 How to Fix Joy-Con Drift Without Disassembly: passo 4, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to lift the rubber ring under the Joy Stick, and hold.
    Pergunte ao FixBot
    Comentar
  5. How to Fix Joy-Con Drift Without Disassembly: passo 5, imagem 1 %32 How to Fix Joy-Con Drift Without Disassembly: passo 5, imagem 2 %32
    • Aim the contact cleaner's nozzle at the gap and spray 404B contact cleaner once or twice.
    Pergunte ao FixBot
    Comentar
  6. How to Fix Joy-Con Drift Without Disassembly: passo 6, imagem 1 %32 How to Fix Joy-Con Drift Without Disassembly: passo 6, imagem 2 %32 How to Fix Joy-Con Drift Without Disassembly: passo 6, imagem 3 %32
    • Rotate the Joy Stick for 30 seconds to allow full penetration of the liquid inside.
    Pergunte ao FixBot
    Comentar
  7. How to Fix Joy-Con Drift Without Disassembly: passo 7, imagem 1 %32
    • Wait 10 minutes for the liquid to dry completely.
    Pergunte ao FixBot
    Comentar
  8. How to Fix Joy-Con Drift Without Disassembly: passo 8, imagem 1 %32 How to Fix Joy-Con Drift Without Disassembly: passo 8, imagem 2 %32 How to Fix Joy-Con Drift Without Disassembly: passo 8, imagem 3 %32
    • Insert the Joy-Con back into the Switch to test the Joy-Con.
    • Navigate to System Settings > Controllers and Sensors > Calibrate Control Sticks.
    • Follow the on-screen prompts on your Switch.
    Pergunte ao FixBot
    Comentar
Conclusão
Enjoy your Joy-Con being able to work properly again!
41 outras pessoas executaram este guia.
Weijie Chen
Membro desde: 01/16/22
1.269 Reputação
Autoria de 1 guia
2Comentários do guia
Muchas gracias.
AlmudenaPita - Responder Compartilhar
Process says it requires compressed air then goes on to use contact cleaner instead.
Mike Burr - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 41
Últimos 7 dias: 317
Últimos 30 dias: 1,555
Ao todo: 110,918
