Ir para o conteúdo principal
How to Factory Reset an iPhone
  1. How to Factory Reset an iPhone, Navigate to the Settings Menu.: passo 1, imagem 1 %32 How to Factory Reset an iPhone, Navigate to the Settings Menu.: passo 1, imagem 2 %32 How to Factory Reset an iPhone, Navigate to the Settings Menu.: passo 1, imagem 3 %32
    • Select the Settings App.
    • If you are unsure where your Settings App is, swipe all the way to the left and use the Search function to pull it up for you.
    Pergunte ao FixBot
    Comentar
  2. How to Factory Reset an iPhone, Find Reset in Settings: passo 2, imagem 1 %32 How to Factory Reset an iPhone, Find Reset in Settings: passo 2, imagem 2 %32
    • Select General. It will likely be along the bottom edge of the first screen.
    • Scroll to the bottom of the following menu. Tap the Reset option. Depending on the version of iOS your phone is running it may alternatively read Transfer or Reset iPhone.
    Pergunte ao FixBot
    Comentar
  3. How to Factory Reset an iPhone, Reset the iPhone: passo 3, imagem 1 %32 How to Factory Reset an iPhone, Reset the iPhone: passo 3, imagem 2 %32 How to Factory Reset an iPhone, Reset the iPhone: passo 3, imagem 3 %32
    • Select the Erase All Content and Settings option.
    • The iPhone will confirm what information will be removed during this process. Click Continue at the bottom of the screen.
    • It will confirm one final time that you want to Erase it. It may ask for your Apple ID password to authenticate.
    Pergunte ao FixBot
    Comentar
  4. How to Factory Reset an iPhone, Wait: passo 4, imagem 1 %32
    • The phone will restart to an Apple logo. A progress bar will appear and fill as the the phone removes data and reinstalls the Operating System.
    • It may restart a few times during the process, or appear to be off for longer than usual between restarts.
    • After patiently waiting, the device will restart to the Setup Assistant allowing you to start configuration from scratch or someone else to do the same.
    Pergunte ao FixBot
    Comentar
Conclusão
The iPhone Setup Assistant will walk you through reactivating and configuring your device. If this reset was done to rule out a software problem, restore your data later. Be sure your issue is resolved without all the additional apps, data and settings changes.
12 outras pessoas executaram este guia.
Alisha C
Membro desde: 12/04/20
42.859 Reputação
Autoria de 9 guias
Equipe
LGBTQ Technicians Membro de LGBTQ Technicians
Community
60 Membros
Autoria de 101 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 17
Últimos 7 dias: 103
Últimos 30 dias: 455
Ao todo: 10,584
