Ir para o conteúdo principal
How to Discharge a Capacitor in Large Machinery
O que você precisa
  1. How to Discharge a Capacitor in Large Machinery, Create a capacitor discharge tool: passo 1, imagem 1 %32 How to Discharge a Capacitor in Large Machinery, Create a capacitor discharge tool: passo 1, imagem 2 %32 How to Discharge a Capacitor in Large Machinery, Create a capacitor discharge tool: passo 1, imagem 3 %32
    • Inspect your capacitor and note the following:
    • The voltage rating of either your capacitor or the device
    • Where the terminals are located
    • Attach two wires to an incandescent lightbulb—making sure the bulb's voltage rating is greater or equal to the capacitor's.
  2. How to Discharge a Capacitor in Large Machinery, Discharge the capacitor: passo 2, imagem 1 %32 How to Discharge a Capacitor in Large Machinery, Discharge the capacitor: passo 2, imagem 2 %32
    • Don't touch the two wire leads together during this step, as this could short circuit the capacitor.
    • Lay one wire lead on the head of the terminal.
    • While holding the lead in place, lay the other wire lead on the opposite terminal to complete the circuit.
    • Hold this position for a few seconds or until the lightbulb completely darkens.
  3. How to Discharge a Capacitor in Large Machinery, Check with a multimeter: passo 3, imagem 1 %32
    • If you have a multimeter, you can check to see if the capacitor is fully drained.
    • Set the meter to its DC voltage measuring mode and measure across the terminals.
    • Any value under 10 volts means your capacitor is sufficiently drained.
Conclusão
For other general electronics skills, click here.
6 outras pessoas executaram este guia.
Alex Diaz-Kokaisl
Membro desde: 01/16/22
162.561 Reputação
Autoria de 769 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 118
Autoria de 19.465 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 12
Últimos 7 dias: 109
Últimos 30 dias: 331
Duração total: 4,184
