Ir para o conteúdo principal
How to Create a Custom Cotton Swab
O que você precisa
    1. How to Create a Custom Cotton Swab, Find a tool: passo 1, imagem 1 %32 How to Create a Custom Cotton Swab, Find a tool: passo 1, imagem 2 %32 How to Create a Custom Cotton Swab, Find a tool: passo 1, imagem 3 %32
      • Find a small object with a pointed end, such as:
      • A toothpick
      • A spudger
      • The end of a flossing pick
      • Avoid metal objects, like paperclips, or anything brittle that might break off in the charging port.
      Pergunte ao FixBot
      Comentar
    2. How to Create a Custom Cotton Swab, Separate the cotton: passo 2, imagem 1 %32 How to Create a Custom Cotton Swab, Separate the cotton: passo 2, imagem 2 %32 How to Create a Custom Cotton Swab, Separate the cotton: passo 2, imagem 3 %32
      • Pull off a small part of a cotton ball.
      • You only need a small amount of cotton—enough to create a thin layer around your tool.
      Pergunte ao FixBot
      Comentar
    3. How to Create a Custom Cotton Swab, Apply the cotton: passo 3, imagem 1 %32 How to Create a Custom Cotton Swab, Apply the cotton: passo 3, imagem 2 %32 How to Create a Custom Cotton Swab, Apply the cotton: passo 3, imagem 3 %32
      • Wrap the cotton around the tip of your tool.
      • Roll the cotton between your fingers to compress it into a thin layer.
      Pergunte ao FixBot
      Comentar
    4. How to Create a Custom Cotton Swab, Remove any excess cotton: passo 4, imagem 1 %32 How to Create a Custom Cotton Swab, Remove any excess cotton: passo 4, imagem 2 %32 How to Create a Custom Cotton Swab, Remove any excess cotton: passo 4, imagem 3 %32
      • Test your cotton swab on your device to see if it fits.
      • If your swab doesn't fit, remove any excess cotton and reroll your cotton so it's compressed and tight along the tip of your tool.
      • If the swab still doesn't fit, you may need to find a different tool altogether.
      • Your custom cotton swab is ready! Return to where you left off in your guide.
      Pergunte ao FixBot
      Comentar
Conclusão
For other general electronics skills guides, click here.
42 outras pessoas executaram este guia.
Alex Diaz-Kokaisl
Membro desde: 01/16/22
246.633 Reputação
Autoria de 1.203 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 48.410 guias
4Comentários do guia
My samsung a14 won't charge
Tebogo madibana - Responder Compartilhar
هاتفي لا يشحن بسبب انخفاض درجة حرارته
لست ادري - Responder Compartilhar
My phone shows green light it doesn't seem to charge
Gm Tessema - Responder Compartilhar
Broken screen
Bemnet Yab - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 31
Últimos 7 dias: 222
Últimos 30 dias: 1,139
Ao todo: 21,816
