Ir para o conteúdo principal
How to Clean Split Air Conditioner
O que você precisa
    1. How to Clean Split Air Conditioner, How to Clean Split Air Conditioner: passo 1, imagem 1 %32
      • The very first thing one has to do while leaning an air conditioner is to turn the unit off and then to unplug it.
      Pergunte ao FixBot
      Comentar
    2. How to Clean Split Air Conditioner, Blow Air without Targeting the Air Reflectors: passo 2, imagem 1 %32
      • Blow air to the air conditioner with air blower but make sure that the air pressure does not get to the air reflectors of the unit.
      Pergunte ao FixBot
      Comentar
    3. How to Clean Split Air Conditioner, Use Cool Water: passo 3, imagem 1 %32
      • Hot water is hazardous for the closely bound metallic plates as they may get expanded due to it. It is advised to use cool water while washing an air conditioner.
      Pergunte ao FixBot
      Comentar
    4. How to Clean Split Air Conditioner, Place the Unit into a Drainable Place: passo 4, imagem 1 %32
      • Garages, porches and courtyards are good places to clean or wash split air conditioners as they mostly have arrangements for water drainage.
      Pergunte ao FixBot
      Comentar
    5. How to Clean Split Air Conditioner, Cover the Wires with Water Proof Material: passo 5, imagem 1 %32
      • It is always better to cover the electric wires of air conditioner with water proofing material. If not done so, then there is a chance for the wires to get wet and this can lead to damage or short circuiting.
      Pergunte ao FixBot
      Comentar
Linha de Chegada
9 outras pessoas executaram este guia.
markirwin
Membro desde: 08/20/16
353 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 28
Últimos 30 dias: 240
Ao todo: 9,720
