Ir para o conteúdo principal
How to Clean Dust out of a PlayStation 5
O que você precisa
  1. How to Clean Dust out of a PlayStation 5, Remove the stand screw: passo 1, imagem 1 %32
    • If your PlayStation 5 is in its vertical orientation, flip it upside down so the stand is facing up.
    • If your PlayStation 5 is in its horizontal orientation, skip to Step 6.
    • Work on a flat surface to prevent your PlayStation from falling over.
    • Use a coin or a flathead screwdriver to remove the 26.5 mm-long stand screw.
  2. How to Clean Dust out of a PlayStation 5, Remove the vertical stand: passo 2, imagem 1 %32 How to Clean Dust out of a PlayStation 5, Remove the vertical stand: passo 2, imagem 2 %32
    • Lift straight up to remove the stand.
  3. How to Clean Dust out of a PlayStation 5, Store the stand screw: passo 3, imagem 1 %32 How to Clean Dust out of a PlayStation 5, Store the stand screw: passo 3, imagem 2 %32
    • Insert the screw into the cubby on the bottom of the stand.
  4. How to Clean Dust out of a PlayStation 5, Cap the screw hole: passo 4, imagem 1 %32 How to Clean Dust out of a PlayStation 5, Cap the screw hole: passo 4, imagem 2 %32 How to Clean Dust out of a PlayStation 5, Cap the screw hole: passo 4, imagem 3 %32
    • Use a pair of tweezers or your fingernail to remove the cap from the cubby.
    • Use your finger to press the cap into the screw hole.
  5. How to Clean Dust out of a PlayStation 5, Close the cubby: passo 5, imagem 1 %32 How to Clean Dust out of a PlayStation 5, Close the cubby: passo 5, imagem 2 %32 How to Clean Dust out of a PlayStation 5, Close the cubby: passo 5, imagem 3 %32
    • Twist the stand counterclockwise to close the cubby.
  6. How to Clean Dust out of a PlayStation 5, Remove the horizontal stand: passo 6, imagem 1 %32 How to Clean Dust out of a PlayStation 5, Remove the horizontal stand: passo 6, imagem 2 %32
    • If your PlayStation 5 is in its horizontal orientation, rest it on its face with the charging port facing up.
    • Lift the stand straight up to remove it.
  7. How to Clean Dust out of a PlayStation 5, Remove the left faceplate: passo 7, imagem 1 %32 How to Clean Dust out of a PlayStation 5, Remove the left faceplate: passo 7, imagem 2 %32 How to Clean Dust out of a PlayStation 5, Remove the left faceplate: passo 7, imagem 3 %32
    • Lift up the corner of the faceplate with the PlayStation logo to unclip it from the case.
  8. How to Clean Dust out of a PlayStation 5: passo 8, imagem 1 %32 How to Clean Dust out of a PlayStation 5: passo 8, imagem 2 %32
    • While lifting up the corner, slide the faceplate towards the bottom of the device.
    • Remove the left faceplate.
  9. How to Clean Dust out of a PlayStation 5, Vacuum out the dust: passo 9, imagem 1 %32 How to Clean Dust out of a PlayStation 5, Vacuum out the dust: passo 9, imagem 2 %32 How to Clean Dust out of a PlayStation 5, Vacuum out the dust: passo 9, imagem 3 %32
    • Use a vacuum to clean out the two dust catchers.
    • A narrow vacuum attachment would be best.
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our PlayStation 5 Answers community for help.
29 outras pessoas executaram este guia.
Robert Boyd
Membro desde: 02/01/21
26.500 Reputação
Autoria de 94 guias
2 comentários
muchas gracias!!! muy facil acabo de hacerle una limpieza a mi consola
J4s3ph - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 132
Últimos 7 dias: 909
Últimos 30 dias: 4,192
Duração total: 95,213
