Ir para o conteúdo principal
How to Clean Calcium Deposits From a Sprinkler Head
O que você precisa
  1. How to Clean Calcium Deposits From a Sprinkler Head, How to Clean Calcium Deposits From a Sprinkler Head: passo 1, imagem 1 %32 How to Clean Calcium Deposits From a Sprinkler Head, How to Clean Calcium Deposits From a Sprinkler Head: passo 1, imagem 2 %32
    • Place your fingers under the edges of the smaller circle, then slowly lift the head.
    • Keep a hose close by to make it easier to clean the basket.
  2. How to Clean Calcium Deposits From a Sprinkler Head: passo 2, imagem 1 %32 How to Clean Calcium Deposits From a Sprinkler Head: passo 2, imagem 2 %32
    • Twist the head counter clockwise to remove the sprinkler head from the neck, exposing the basket.
  3. How to Clean Calcium Deposits From a Sprinkler Head: passo 3, imagem 1 %32 How to Clean Calcium Deposits From a Sprinkler Head: passo 3, imagem 2 %32
    • If working with two people, use one hand to hold the base of the neck so the sprinkler doesn't fall back into the body of the sprinkler.
    • If working by yourself, slowly release the neck back down. It is still retrievable by twisting the head back on and repeating the process in step 2.
  4. How to Clean Calcium Deposits From a Sprinkler Head: passo 4, imagem 1 %32
    • Use the hose to wash out the basket of any dirt or calcium deposits.
  5. How to Clean Calcium Deposits From a Sprinkler Head: passo 5, imagem 1 %32
    • Reassemble the head, placing back the basket in the center of the neck and twisting the head clockwise to tighten it down.
  6. How to Clean Calcium Deposits From a Sprinkler Head: passo 6, imagem 1 %32
    • Release the neck and the sprinkler is clean and ready for use.
Conclusão
Once the head is reassembled the water flow should no longer be obstructed and should regain the full range of spray.
Max Warrick
Membro desde: 07/03/23
133 Reputação
Autoria de 1 guia
Um comentário
question: What is the flathead screw in the center of the sprinkler head for?
David Franco - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 15
Duração total: 389
