Introdução
This preventive maintenance is to prevent your HV battery from overheating. Over time, the fan can accumulate dirt and dust from the passenger compartment and clogs up the fins. Once that happens, it'll cause the fan to not work sufficiently to cool down the battery and thus will cause a check engine light P0A82. By doing this preventive maintenance, you will prevent the Hybrid battery from overheating. I would recommend doing this every 60k miles if you have shedding pets that sits in the back.
To clear the error code on the dashboard, disconnect the 12 volt battery on the passenger rear trunk and reconnect it.
Follow this video tutorial by YouTuber NutzAboutBolts to complete the Cleaning yourself.
Safety
If this is your first time working on a vehicle read our safety tips before proceeding.
O que você precisa
Instruções em vídeo
4 outras pessoas executaram este guia.
3 comentários
Excellent video. Was considering doing the cleaning myself after several alarms came it. Also noticed the fan was making abnormal noise. Yes, we have a border collie dog that rides back there sometimes.
Eddie Brown - Responder
Thank you so much for this tutorial video.
vallinaso - Responder
Removal of the vent cover (at 4:50) was complicated by the presence of a 12mm bolt at the bottom of the piece. Once removed, the piece came out easily.
Stephen Weeks - Responder
