Ir para o conteúdo principal
How to Check Battery Health Using CROSH
      • From your Desktop use the key combination Ctrl + Alt + T
      Pergunte ao FixBot
      Comentar
      • In the CROSH terminal type in battery_test [< test length >]
      • The test length is measured in seconds. if no number is put in, then the test length will default to 300 seconds.
      Pergunte ao FixBot
      Comentar
      • You can also use the command battery_firmware info to get additional information about your battery's including serial number, chemistry, and design capacity.
      Pergunte ao FixBot
      Comentar
Conclusão
This command is extremely useful for determining if your Chromebook's battery is operating at peak performance, of if there is an issue with the battery.
5 outras pessoas executaram este guia.
Jacob Mehnert
Membro desde: 10/18/21
49.564 Reputação
Autoria de 52 guias
Equipe
iFanatics Membro de iFanatics
Community
69 Membros
Autoria de 850 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 30
Últimos 30 dias: 101
Ao todo: 6,100
