Ir para o conteúdo principal
How to Change Ukulele Strings For Left Handed Players
O que você precisa
  1. How to Change Ukulele Strings For Left Handed Players, Ukulele Strings: passo 1, imagem 1 %32 How to Change Ukulele Strings For Left Handed Players, Ukulele Strings: passo 1, imagem 2 %32 How to Change Ukulele Strings For Left Handed Players, Ukulele Strings: passo 1, imagem 3 %32
    • Unwind and clip the strings.
    • Remove the strings.
  2. How to Change Ukulele Strings For Left Handed Players: passo 2, imagem 1 %32
    • The string order for a right handed ukulele is G-C-E-A, so we will put the strings in the reverse order for left handed people, A-E-C-G.
    • Feed the new strings through the holes in the bridge.
  3. How to Change Ukulele Strings For Left Handed Players: passo 3, imagem 1 %32 How to Change Ukulele Strings For Left Handed Players: passo 3, imagem 2 %32 How to Change Ukulele Strings For Left Handed Players: passo 3, imagem 3 %32
    • Leave approximately 4 inches so you are able to tie the knot.
    • To tie the strings in a double knot, make a loose knot with the strings.
    • Feed the string back through the opening (as seen in the second image).
    • Once it is fed through the opening, pull it tight.
    • Tug on the string to ensure it is secure to the bridge.
  4. How to Change Ukulele Strings For Left Handed Players: passo 4, imagem 1 %32 How to Change Ukulele Strings For Left Handed Players: passo 4, imagem 2 %32 How to Change Ukulele Strings For Left Handed Players: passo 4, imagem 3 %32
    • Once the strings are secured to the bridge, feed the strings through their corresponding tuning peg holes.
    • Wrap it around outwardly.
    • Feed it through the tuning peg again for a tighter fit.
  5. How to Change Ukulele Strings For Left Handed Players: passo 5, imagem 1 %32
    • Ensure that the strings are wrapped around the tuning pegs from the inside out.
    • This image shows the direction the strings should be facing.
  6. How to Change Ukulele Strings For Left Handed Players: passo 6, imagem 1 %32
    • Once the strings have been secured to their tuning pegs, wind each tuning peg in a counter-clockwise direction.
    • Wind each string roughly 15-20 times, or until the strings are tight and no longer loose.
    • Finally, tune your ukulele, and you're done!
Conclusão
Your ukulele is now playable for a left handed person!
Leah Garcia
Membro desde: 09/27/24
133 Reputação
Autoria de 1 guia
Equipe
CSU Sacramento, Team 1-9, Laflen Fall 2024 Membro de CSU Sacramento, Team 1-9, Laflen Fall 2024
CSUSAC-LAFLEN-F24S1G9
1 Membro
1 Guia de autoria
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 14
Últimos 30 dias: 43
Ao todo: 347
