Introdução
Follow this guide to assemble the iMac Cardboard Service Wedge, which ships unfolded and flat. Once assembled, this product is not designed to be unfolded.
O que você precisa
With the blank side facing you, fold the two tabs inward at a 90-degree angle.
Fold the two halves together, using the crease in the center as the folding point.
Overlap the two outer side flaps, making sure the flap with the two small tabs is on top.
Your iMac Cardboard Service Wedge is ready to go!
Insert the Service Wedge under the iMac's display to hold it in place while you perform repairs on your iMac.
51 outras pessoas executaram este guia.
