Ir para o conteúdo principal
How to Access the Internal Components of an HP 15-R011DX
O que você precisa
  1. How to Access the Internal Components of an HP 15-R011DX, Battery: passo 1, imagem 1 %32 How to Access the Internal Components of an HP 15-R011DX, Battery: passo 1, imagem 2 %32
    • Slide the lock mechanism on the left side of the laptop to the right.
    Pergunte ao FixBot
    Comentar
  2. How to Access the Internal Components of an HP 15-R011DX: passo 2, imagem 1 %32
    • While holding the right slide mechanism, remove the battery from the laptop.
    • The battery is not pictured here because it is missing from this particular device.
    Pergunte ao FixBot
    Comentar
  3. How to Access the Internal Components of an HP 15-R011DX, How to Access the Internal Components of an HP 15-R011DX: passo 3, imagem 1 %32 How to Access the Internal Components of an HP 15-R011DX, How to Access the Internal Components of an HP 15-R011DX: passo 3, imagem 2 %32
    • Flip the laptop over to reveal screw locations.
    • Use a metal spudger to remove the two rear rubber feet. There are screws hidden underneath them.
    Pergunte ao FixBot
    Comentar
  4. How to Access the Internal Components of an HP 15-R011DX: passo 4, imagem 1 %32 How to Access the Internal Components of an HP 15-R011DX: passo 4, imagem 2 %32
    • Remove the twelve 5mm Phillips #1 screws on the back of the laptop.
    Pergunte ao FixBot
    Comentar
  5. How to Access the Internal Components of an HP 15-R011DX: passo 5, imagem 1 %32 How to Access the Internal Components of an HP 15-R011DX: passo 5, imagem 2 %32
    • Remove the DVD drive from the laptop.
    • Remove the two 3 mm Phillips #1 screws underneath the DVD drive.
    Pergunte ao FixBot
    Comentar
  6. How to Access the Internal Components of an HP 15-R011DX: passo 6, imagem 1 %32 How to Access the Internal Components of an HP 15-R011DX: passo 6, imagem 2 %32 How to Access the Internal Components of an HP 15-R011DX: passo 6, imagem 3 %32
    • Flip the laptop and open.
    • Detach the keyboard by prying it free from the laptop using a spudger.
    • Do not completely remove the keyboard yet. It is still attached by a ribbon cable.
    • Disconnect the keyboard ribbon cable.
    Pergunte ao FixBot
    Comentar
  7. How to Access the Internal Components of an HP 15-R011DX: passo 7, imagem 1 %32 How to Access the Internal Components of an HP 15-R011DX: passo 7, imagem 2 %32
    • Disconnect the two narrow ribbon cables to the left of the keyboard connection.
    • Remove five 4 mm Phillips #1 screws from the metal tray for the keyboard.
    • Pry open the plastic casing using a spudger.
    • If struggling to remove the plastic case, check that all screws have been removed.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 25
Ao todo: 810
