Ir para o conteúdo principal
How to Access GE Washing Machine Error Code Mode
Guia de vídeo
Este guia foi transcrito de um vídeo do YouTube.
    • Unplug the washing machine for about five minutes and then reconnect power.
    • Ensure the display is blank and no cycle is running before proceeding.
    Pergunte ao FixBot
    Comentar
    • Press and hold the Start/Pause button for 10 seconds until the display lights up.
    • Release the button when the first stored code appears.
    Pergunte ao FixBot
    Comentar
    • Press Start/Pause again to cycle through each stored error code.
    • Two horizontal lines on the display mean you have reached the end of the list.
    Pergunte ao FixBot
    Comentar
    • Press any button on the right side of the control panel except Start or Power.
    • Confirm the display shuts down and the washer exits error code mode.
    Pergunte ao FixBot
    Comentar
    • Compare the code on the display with GE's fault list.
    • Use that code to focus your troubleshooting before replacing parts.
    Pergunte ao FixBot
    Comentar
    • Press and hold the Start button while rotating the selector knob 180 degrees counterclockwise.
    • Release Start when the display begins flashing.
    • If you overshoot slightly, return the knob to its starting position and try again.
    Pergunte ao FixBot
    Comentar
    • Turn the knob clockwise to increase the test number or counterclockwise to decrease it.
    • Press Start once to begin the selected test.
    • Test 1 returns to the stored error code mode from the earlier steps.
    Pergunte ao FixBot
    Comentar
    • Press and hold Start/Pause for 10 seconds to reset the washer.
    • Confirm the display returns to normal operation afterward.
    Pergunte ao FixBot
    Comentar
    • Check for alerts such as H2O Supply when water flow is restricted or turned off.
    • Watch for a door alert if the washer does not sense a closed or locked lid.
    • If the spin light blinks, rebalance the load and inspect for out-of-balance conditions.
    • If the display shows Cancelled, close the lid and try again, or power-cycle the washer if needed.
    Pergunte ao FixBot
    Comentar
    • Record the stored codes and any service-test results before making repairs.
    • Future models may add more test numbers, but the basic entry steps are usually the same.
    Pergunte ao FixBot
    Comentar
Conclusão
Use the stored codes and service tests to narrow the fault before replacing parts. Exit diagnostics when you're done and return the washer to normal operation. Repair didn't go as planned? Ask our Answers community for help.
Ben Schlichter
Membro desde: 01/21/25
6.551 Reputação
Autoria de 224 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 51
Últimos 7 dias: 218
Últimos 30 dias: 825
Ao todo: 8,435
