Ir para o conteúdo principal
How To Reset a Suitcase Lock
    1. How To Reset a Suitcase Lock, How To Reset a Suitcase Lock: passo 1, imagem 1 %32 How To Reset a Suitcase Lock, How To Reset a Suitcase Lock: passo 1, imagem 2 %32
      • Set the suitcase down with the combination lock facing up.
      Pergunte ao FixBot
      Comentar
    2. How To Reset a Suitcase Lock: passo 2, imagem 1 %32
      • Turn a flashlight towards the lock, so that you can see the small details.
      Pergunte ao FixBot
      Comentar
    3. How To Reset a Suitcase Lock: passo 3, imagem 1 %32 How To Reset a Suitcase Lock: passo 3, imagem 2 %32 How To Reset a Suitcase Lock: passo 3, imagem 3 %32
      • Rotate the three gears together so that the grooved part of each gear faces the outside.
      • Correct: Gear faces the outside.
      • Gear faces the inside.
      Pergunte ao FixBot
      Comentar
    4. How To Reset a Suitcase Lock: passo 4, imagem 1 %32
      • Remember the number of the three gears when the groove part is on the outside.
      • As of now the code number of the three gears is 181.
      Pergunte ao FixBot
      Comentar
    5. How To Reset a Suitcase Lock: passo 5, imagem 1 %32
      • Add 5 to each of the three numbers. For example, my numbers are 181. After adding 5, the code to my lock would be 636.
      • Turn the numbers on the lock to 636, and then unlock the lock.
      Pergunte ao FixBot
      Comentar
    6. How To Reset a Suitcase Lock: passo 6, imagem 1 %32 How To Reset a Suitcase Lock: passo 6, imagem 2 %32
      • Sometimes the difference is not 5 from the grooved spots. In this case, you can try to increase the numbers after adding 5.
      • For example, if 636 does not work, try to add 6 to the three numbers. Then the code is 747 and attempt to unlock the lock. Continue to add 7, then 8 to try, until it can be opened.
      Pergunte ao FixBot
      Comentar
    7. How To Reset a Suitcase Lock: passo 7, imagem 1 %32 How To Reset a Suitcase Lock: passo 7, imagem 2 %32
      • When I added 8 and my number was 969, the lock unlocked. We successfully opened the suitcase!
      Pergunte ao FixBot
      Comentar
Conclusão
After reading my guide, you will never encounter the problem that the suitcase cannot be opened without remembering the password. It can be solved anytime, anywhere.
6 outras pessoas executaram este guia.
Lisha Li
Membro desde: 09/17/21
469 Reputação
Autoria de 2 guias
Equipe
4Comentários do guia
OMG! A big THANK YOU!!! It worked.
Edward Lee - Responder Compartilhar
Amazing. This worked for me
Leena Daykin - Responder Compartilhar
It worked for me too
georgeteach - Responder Compartilhar
Surprised ! And grateful also to the author. I opened the lock with forgotten combination in just 3 minutes.
Chandrashekhar Dadhekar - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 16
Últimos 7 dias: 127
Últimos 30 dias: 712
Ao todo: 58,940
