Introdução
In this guide we’re going to be fixing a classic 2011 Wii Remote Charger, also occasionally known as a Wii Dual Charging Station, specifically we’ll be addressing how to fix one with a broken capacitor. Within the guide is a step teaching how to tell if it’s the capacitor that is broken, testing and troubleshooting it to ensure this is the necessary fix. Due to the nature of the symptoms of a broken capacitor it’s difficult if not impossible to tell if this is the appropriate fix without completing this step. Please keep in mind that this guide does include soldering which can be dangerous for first-time users.
O que você precisa
Now that we've located the capacitor on the circuit board, we'll be using two different tests on an ohmmeter to see if the capacitor works or not:
The first test isn't necessary, but can be used as a quick way to indicate function. If the capacitor works the meter will indicate full continuity by beeping. If it fails the test it won't beep, showing an open circuit and we need to move on to the next test. To start the test use any ohms meter and turn the dial to what's depicted in the picture.
The second test is a verification of the capacitor. The measures the capacitance of Farads. If the test is successful it'll indicate 1000 UF. A different number will indicate that the test is a failure and the capacitor needs to be replaced. To start the test use any ohmmeter and turn the dial to what's depicted in the picture.
Congratulations on fixing your Wii Remote Charger.
