Ir para o conteúdo principal
How To Remove Rust From Old Tools
O que você precisa
    1. How To Remove Rust From Old Tools, How To Remove Rust From Old Tools: passo 1, imagem 1 %32 How To Remove Rust From Old Tools, How To Remove Rust From Old Tools: passo 1, imagem 2 %32
      • Removing rust generally isn't dangerous, but it's pretty messy.
      • Prepare your workspace by laying out an old towel or shop rag that you won't mind getting dirty.
      • Consider also wearing protective gloves.
      • Place your tool on the towels.
      Pergunte ao FixBot
      Comentar
    2. How To Remove Rust From Old Tools: passo 2, imagem 1 %32 How To Remove Rust From Old Tools: passo 2, imagem 2 %32
      • Spray the rusty areas of the tool with a generous amount of WD-40.
      Pergunte ao FixBot
      Comentar
    3. How To Remove Rust From Old Tools: passo 3, imagem 1 %32 How To Remove Rust From Old Tools: passo 3, imagem 2 %32 How To Remove Rust From Old Tools: passo 3, imagem 3 %32
      • Use a scouring pad to thoroughly scrub the tool.
      • It shouldn't take a lot of force—the WD-40 and scouring pad will do most of the work.
      Pergunte ao FixBot
      Comentar
    4. How To Remove Rust From Old Tools: passo 4, imagem 1 %32 How To Remove Rust From Old Tools: passo 4, imagem 2 %32 How To Remove Rust From Old Tools: passo 4, imagem 3 %32
      • Use a paper towel to wipe away the excess grime and WD-40.
      Pergunte ao FixBot
      Comentar
    5. How To Remove Rust From Old Tools: passo 5, imagem 1 %32
      • Continue scouring the tool, adding more WD-40 as needed, until the surface is free of rust.
      • When you finish, your tool may not look brand new—but the surface should now be rust-free and ready for years of continued use.
      Pergunte ao FixBot
      Comentar
Conclusão
13 outras pessoas executaram este guia.
Geoff Wacker
Membro desde: 09/30/13
92.939 Reputação
Autoria de 88 guias
3Comentários do guia
Apple cider vinegar removes rust well. Try it.
Michael Jucker - Responder Compartilhar
Thank you I have tried vinagar ,rust buster and other sprays and only the WD 40 worked best
Ronald Tyler - Responder Compartilhar
Coca-Cola also works, soak over night
Gil Flores - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 41
Últimos 30 dias: 177
Ao todo: 9,285
