Ir para o conteúdo principal
Essa tradução foi gerada por um programa e ainda não foi revisada por uma pessoa. Falas essa língua? Dá uma olhada.
Diagnóstico de falhas de PS3 usando o REGISTRO DE ERROS DO SYSCON (YLOD)
Conclusão
Para a remontagem de seu dispositivo, siga estas instruções na ordem inversa.
Slot1gamer
Membro desde: 11/21/13
749 Reputação
Autoria de 1 guia
Equipe
ModChipGuys Membro de ModChipGuys
Business
1 Membro
Autoria de 12 guias
6Comentários do guia
There are some notes here, the GUI version you have listed will not give the full bringup for syscon, this doesn’t give people enough accurate data to see what exactly is going on, I would recommend you link RIP-Felix’s video as well as that has more in depth explanation on the python version of syscon which is more reliable than the GUI, it’s a good video but I would definitely go with the python version over the GUI just from how many bugs I have had in the past with that
Nascar1243 - Responder Compartilhar
Also I forgot to mention it would also be nice to have a step by step guide written out so people don’t have to refer to a video for guidance, there are people who would rather read along and have the video as a backup than have only a video
Mi ps3 fat pasa esto cuando yo soluciono el juego como gta 5 ohh wwe 16 etc se me ve algunas veces la pantalla en negra ohh cuando inicia cuando estoy jugando en esos juego que dije a los 20 minutos se me apaga pero cuando entro al fifa no se me apaga porque sera ? Si dicen que es por mantenimiento ya esta limpia de polvo y la pasta termica
Jesus levy Urdaneta - Responder Compartilhar
It’s more than likely going to be tokins but without the syscon logs it’s hard to say, you don’t have to follow this guide, you can use ps3toolset.com to get your codes if your console boots.
Mi ps3 se apaga a cabo de unos 20 minutos
Qué será!?
Juan Marcos Ekang - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 16
Últimos 7 dias: 147
Últimos 30 dias: 738
Ao todo: 15,221
