Ir para o conteúdo principal
How To Clean Nikon Coolpix S30 Lens
O que você precisa
    1. How To Clean Nikon Coolpix S30 Lens, Batteries: passo 1, imagem 1 %32 How To Clean Nikon Coolpix S30 Lens, Batteries: passo 1, imagem 2 %32
      • Slide the battery cover to the right.
      • The hinge is on the left side of the cover which will allow the cover to stay attached.
      Pergunte ao FixBot
      Comentar
    2. How To Clean Nikon Coolpix S30 Lens: passo 2, imagem 1 %32 How To Clean Nikon Coolpix S30 Lens: passo 2, imagem 2 %32
      • Slide the second cover (yellow) to the right (similar to the outer cover). This will allow the batteries to be exposed.
      Pergunte ao FixBot
      Comentar
    3. How To Clean Nikon Coolpix S30 Lens: passo 3, imagem 1 %32
      • Remove the batteries by gently tipping the camera.
      Pergunte ao FixBot
      Comentar
    1. How To Clean Nikon Coolpix S30 Lens, How To Clean Nikon Coolpix S30 Lens: passo 4, imagem 1 %32
      • Remove the four screws the hold the back of the case to the rest of the camera.
      Pergunte ao FixBot
      Comentar
    2. How To Clean Nikon Coolpix S30 Lens: passo 5, imagem 1 %32
      • Remove the left screw from the bottom of the camera first. This can be done using the same T5 tip.
      • Unscrew the screw on the right using a different attachment: PH000 (it is a small Phillip's head)
      Pergunte ao FixBot
      Comentar
    3. How To Clean Nikon Coolpix S30 Lens: passo 6, imagem 1 %32
      • Remove back case from the rest of the camera carefully.
      Pergunte ao FixBot
      Comentar
    4. How To Clean Nikon Coolpix S30 Lens: passo 7, imagem 1 %32
      • Remove the three screws the secure the motherboard to the front case.
      Pergunte ao FixBot
      Comentar
    5. How To Clean Nikon Coolpix S30 Lens: passo 8, imagem 1 %32 How To Clean Nikon Coolpix S30 Lens: passo 8, imagem 2 %32
      • Remove the motherboard from the front case.
      • Leave the red and black wire attached but lay the piece in front of the case.
      Pergunte ao FixBot
      Comentar
    6. How To Clean Nikon Coolpix S30 Lens: passo 9, imagem 1 %32 How To Clean Nikon Coolpix S30 Lens: passo 9, imagem 2 %32
      • Wipe the lens and the clear plastic on the front case to remove debris.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Penn State, Team 2-4, Kaschak Winter 2015 Membro de Penn State, Team 2-4, Kaschak Winter 2015
PSU-KASCHAK-W15S2G4
4 Membros
Autoria de 5 guias
1Comentário do guia
The first three steps are redundant because you already included the prerequisite guide for removal of the batteries.
Dylan Keiter - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 23
Ao todo: 2,102
