Ir para o conteúdo principal
Hoverboard Bluetooth Remote Control Replacement
O que você precisa
    1. Hoverboard Bluetooth Remote Control Replacement, Bluetooth Remote Control: passo 1, imagem 1 %32
      • Remove the 10 screws with a Phillips screwdriver to access the inside of the hoverboard.
      • The electronic circuit boards are mirrored on both sides, so examine them both to determine which has the Bluetooth setup.
      Pergunte ao FixBot
      Comentar
    2. Hoverboard Bluetooth Remote Control Replacement: passo 2, imagem 1 %32
      • Unhook the lighting and indicator light wires to remove the cover.
      Pergunte ao FixBot
      Comentar
    3. Hoverboard Bluetooth Remote Control Replacement: passo 3, imagem 1 %32
      • Remove the 4 screws that hold the circuit board support.
      Pergunte ao FixBot
      Comentar
    4. Hoverboard Bluetooth Remote Control Replacement: passo 4, imagem 1 %32
      • Remove the 4 screws that secure the board to the support.
      Pergunte ao FixBot
      Comentar
    5. Hoverboard Bluetooth Remote Control Replacement: passo 5, imagem 1 %32
      • Remember the sequence of wires to be soldered on the Bluetooth board.
      Pergunte ao FixBot
      Comentar
    6. Hoverboard Bluetooth Remote Control Replacement: passo 6, imagem 1 %32
      • Use a soldering iron to affix the 4 pins of the Bluetooth board onto the hoverboard board
      • Before soldering the boards, check the functionality of the Bluetooth board by merely inserting the pins, which is enough.
      Pergunte ao FixBot
      Comentar
Conclusão
To reassemble your device, Follow these instructions in reverse order.
Uma outra pessoa concluiu este guia.
Um agradecimento especial a esses tradutores:
it en
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Smilzo
Membro desde: 11/09/13
12.359 Reputação
Autoria de 39 guias
4Comentários do guia
Hello! Would it be possible to know where to get that bluetooth module? I would like to try that one my hoverboard but cant find the needed part.
Nix Mathy - Responder Compartilhar
Ciao,puoi cercare su EBay AliExpress Wish ed altri store cinesi
Smilzo - Responder Compartilhar
Well after 5 days of search on ali.. ebay.. bangood.. amazon. I still haven't found the good part.
I've ask a lots of sellers and they all replied the module they sell is only for music no app control :(
Nix Mathy devi cercare bene come parola chiave.io li vedo su tanti store
telecomando self balance hoverboard
https://www.amazon.it/Hoverboard-Telecom...
https://www.ebay.it/itm/REPLACEMENT-REMO...
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 12
Últimos 30 dias: 89
Ao todo: 2,360
