Ir para o conteúdo principal
Hover-1 XLS Battery Replacement
O que você precisa
  1. Hover-1 XLS Battery Replacement, Battery: passo 1, imagem 1 %32 Hover-1 XLS Battery Replacement, Battery: passo 1, imagem 2 %32 Hover-1 XLS Battery Replacement, Battery: passo 1, imagem 3 %32
    • Remove the four, 12mm Hex #3 screws located on the bottom half of the battery compartment.
    • There are four screws that need to remove. Two on one side and the two on the opposite side.
    Pergunte ao FixBot
    Comentar
  2. Hover-1 XLS Battery Replacement: passo 2, imagem 1 %32 Hover-1 XLS Battery Replacement: passo 2, imagem 2 %32 Hover-1 XLS Battery Replacement: passo 2, imagem 3 %32
    • Remove the adhesive holding the wires tightly.
    • You can use a sharp object to score the adhesive before pulling.
    • Pull on both sides of the wire connections.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Equipe
Cal Poly, Team S1-G2, White Winter 2019 Membro de Cal Poly, Team S1-G2, White Winter 2019
CPSU-WHITE-W19S1G2
3 Membros
Autoria de 13 guias
17Comentários do guia
That looks easy enough to do. My problem is finding a replacement battery. Do you have any idea where they are available?
David Schultze - Responder Compartilhar
David did you happen to find one? Please let me know I've been looking for one
Michael Hawk - Responder Compartilhar
If anyone find a 1:1 replacement battery for this, or at the very least a wiring diagram, please post it as it's near impossible to find anything on this thing in 2022.
GutZ Era - Responder Compartilhar
So the yellow and a red are for the ignition and the other red and black ig is a standard ground and positive with the white being I think the temperature sensore wire. Hope this helps also trying to find a replacement and may try wiring one up.
Batman and King - Responder Compartilhar
Hi, where can you find the battery replacement? I have my scooter and the battery needs to be replaced.
Mary - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 57
Últimos 30 dias: 249
Ao todo: 14,344
