Ir para o conteúdo principal
Hover-1 Titan Left Gyroscope Replacement
O que você precisa
  1. Hover-1 Titan Left Gyroscope Replacement, Bottom Left Panel: passo 1, imagem 1 %32 Hover-1 Titan Left Gyroscope Replacement, Bottom Left Panel: passo 1, imagem 2 %32
    • Flip the hoverboard so the bottom is facing up.
    • The left side is the side that has the charge port. There is also an "L" on the metal plate underneath the wires.
    Pergunte ao FixBot
    Comentar
  2. Hover-1 Titan Left Gyroscope Replacement: passo 2, imagem 1 %32 Hover-1 Titan Left Gyroscope Replacement: passo 2, imagem 2 %32
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws located closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove two 15 mm screws located closest to the wheel.
    Pergunte ao FixBot
    Comentar
  3. Hover-1 Titan Left Gyroscope Replacement: passo 3, imagem 1 %32 Hover-1 Titan Left Gyroscope Replacement: passo 3, imagem 2 %32 Hover-1 Titan Left Gyroscope Replacement: passo 3, imagem 3 %32
    • Grip the bottom left panel and lift up to remove.
    Pergunte ao FixBot
    Comentar
  4. Hover-1 Titan Left Gyroscope Replacement, Left Gyroscope and Motherboard: passo 4, imagem 1 %32 Hover-1 Titan Left Gyroscope Replacement, Left Gyroscope and Motherboard: passo 4, imagem 2 %32
    • Unplug the battery from the gyroscope by holding the yellow connector and pulling apart.
    Pergunte ao FixBot
    Comentar
  5. Hover-1 Titan Left Gyroscope Replacement: passo 5, imagem 1 %32 Hover-1 Titan Left Gyroscope Replacement: passo 5, imagem 2 %32 Hover-1 Titan Left Gyroscope Replacement: passo 5, imagem 3 %32
    • Remove four 12 mm Phillips #1 head screws from the corners of the green gyroscope/motherboard.
    Pergunte ao FixBot
    Comentar
  6. Hover-1 Titan Left Gyroscope Replacement: passo 6, imagem 1 %32 Hover-1 Titan Left Gyroscope Replacement: passo 6, imagem 2 %32
    • Unplug the bottom right connector by squeezing it and pulling it away from the board.
    Pergunte ao FixBot
    Comentar
  7. Hover-1 Titan Left Gyroscope Replacement: passo 7, imagem 1 %32 Hover-1 Titan Left Gyroscope Replacement: passo 7, imagem 2 %32
    • Unplug the light connector by squeezing it and pulling away from the board.
    Pergunte ao FixBot
    Comentar
  8. Hover-1 Titan Left Gyroscope Replacement: passo 8, imagem 1 %32 Hover-1 Titan Left Gyroscope Replacement: passo 8, imagem 2 %32
    • Unplug the blue and white wires by squeezing the connector and pulling away from the board.
    Pergunte ao FixBot
    Comentar
  9. Hover-1 Titan Left Gyroscope Replacement: passo 9, imagem 1 %32 Hover-1 Titan Left Gyroscope Replacement: passo 9, imagem 2 %32
    • Unplug the small white connector by squeezing it and pulling away from the board.
    Pergunte ao FixBot
    Comentar
  10. Hover-1 Titan Left Gyroscope Replacement: passo 10, imagem 1 %32 Hover-1 Titan Left Gyroscope Replacement: passo 10, imagem 2 %32
    • Unplug the plug in the red connector.
    • The red plug is glued to the board, so this step will require extra force.
    Pergunte ao FixBot
    Comentar
  11. Hover-1 Titan Left Gyroscope Replacement: passo 11, imagem 1 %32 Hover-1 Titan Left Gyroscope Replacement: passo 11, imagem 2 %32
    • Unplug the charging cable connector by squeezing it and pulling it away from the board.
    Pergunte ao FixBot
    Comentar
  12. Hover-1 Titan Left Gyroscope Replacement: passo 12, imagem 1 %32
    • Cut the cable tie.
    • Unplug the remaining wires.
    • The connectors for the remaining wires are in the rubber covers.
    Pergunte ao FixBot
    Comentar
Conclusão
Jessica Ouyang
Membro desde: 10/08/18
634 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team S15-G4, White Fall 2018 Membro de Cal Poly, Team S15-G4, White Fall 2018
CPSU-WHITE-F18S15G4
4 Membros
Autoria de 10 guias
2Comentários do guia
I’ve got an active broken on the cover not the one to to speaker the other one. Does anyone know where is terminates. I can’t see where it came from. It can only reach the circuit board or the active of the speaker.
Mark - Responder Compartilhar
Where do you buy the board?
eden11 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 55
Ao todo: 1,668
