Ir para o conteúdo principal
Hover-1 Superstar Front Bumper LED Replacement
O que você precisa
    1. Hover-1 Superstar Front Bumper LED Replacement, Bottom Case: passo 1, imagem 1 %32 Hover-1 Superstar Front Bumper LED Replacement, Bottom Case: passo 1, imagem 2 %32 Hover-1 Superstar Front Bumper LED Replacement, Bottom Case: passo 1, imagem 3 %32
      • Flip your Hover-1 Superstar device upside down.
      • Using a Phillips #1 screwdriver, remove all twenty of the 18mm screws holding the case onto the device.
      • Remove the bottom case. Be careful of the connector holding the case and the device together.
      Pergunte ao FixBot
      Comentar
    2. Hover-1 Superstar Front Bumper LED Replacement: passo 2, imagem 1 %32
      • Locate the cable connected to the front lights.
      • Pull apart the wires until the black clip separates.
      Pergunte ao FixBot
      Comentar
    1. Hover-1 Superstar Front Bumper LED Replacement, Front Bumper LED: passo 3, imagem 1 %32
      • Grab the wire of the connector you disconnected from the case earlier and slide the entire light out away from the case.
      Pergunte ao FixBot
      Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 16
Ao todo: 535
