Ir para o conteúdo principal
Hover-1 Superstar Battery Replacement
O que você precisa
    1. Hover-1 Superstar Battery Replacement, Bottom Case: passo 1, imagem 1 %32 Hover-1 Superstar Battery Replacement, Bottom Case: passo 1, imagem 2 %32 Hover-1 Superstar Battery Replacement, Bottom Case: passo 1, imagem 3 %32
      • Flip your Hover-1 Superstar device upside down.
      • Using a Phillips #1 screwdriver, remove all twenty of the 18mm screws holding the case onto the device.
      • Remove the bottom case. Be careful of the connector holding the case and the device together.
      Pergunte ao FixBot
      Comentar
    2. Hover-1 Superstar Battery Replacement: passo 2, imagem 1 %32
      • Locate the cable connected to the front lights.
      • Pull apart the wires until the black clip separates.
      Pergunte ao FixBot
      Comentar
    1. Hover-1 Superstar Battery Replacement, Battery: passo 3, imagem 1 %32 Hover-1 Superstar Battery Replacement, Battery: passo 3, imagem 2 %32
      • Locate the four 14mm screws securing the battery bracket.
      • Remove the screws with a Phillips #1 screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Hover-1 Superstar Battery Replacement: passo 4, imagem 1 %32
      • Pull and disconnect the cable connector that is connected to the battery.
      Pergunte ao FixBot
      Comentar
    3. Hover-1 Superstar Battery Replacement: passo 5, imagem 1 %32
      • Pull on the battery until it separates from the hover board. You may need to use some force.
      • Be sure the battery is disconnected before performing this step to avoid electrocution.
      • There will be a loud crack when the battery is removed. This is normal due to the adhesive on the back of the battery.
      • Pull the battery out of the hoverboard. Move wires away from the battery if necessary.
      Pergunte ao FixBot
      Comentar
Conclusão
1Comentário do guia
How do u get a 25.2v battery at for my hover-1
chivitbprince Boonking - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 37
Ao todo: 2,397
