Ir para o conteúdo principal
Hover-1 Liberty Gyroscope Sensor Boards Replacement
O que você precisa
  1. Hover-1 Liberty Gyroscope Sensor Boards Replacement, Bottom Cover: passo 1, imagem 1 %32 Hover-1 Liberty Gyroscope Sensor Boards Replacement, Bottom Cover: passo 1, imagem 2 %32
    • Flip the hoverboard over so the labels are facing upwards.
    • Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
    Pergunte ao FixBot
    Comentar
  2. Hover-1 Liberty Gyroscope Sensor Boards Replacement: passo 2, imagem 1 %32 Hover-1 Liberty Gyroscope Sensor Boards Replacement: passo 2, imagem 2 %32
    • Remove the bottom cover by lifting it away from the hoverboard.
    • The cover on the side without the battery has two wires connecting the power button and charging port.
    Pergunte ao FixBot
    Comentar
  3. Hover-1 Liberty Gyroscope Sensor Boards Replacement: passo 3, imagem 1 %32 Hover-1 Liberty Gyroscope Sensor Boards Replacement: passo 3, imagem 2 %32 Hover-1 Liberty Gyroscope Sensor Boards Replacement: passo 3, imagem 3 %32
    • Remove one connector from the non-battery side circuit board.
    • Remove the next connector from the non-battery side circuit board.
    • To remove the connectors, pinch the plug and pull away from the circuit board.
    Pergunte ao FixBot
    Comentar
  4. Hover-1 Liberty Gyroscope Sensor Boards Replacement, Gyroscope Sensor Boards: passo 4, imagem 1 %32
    • Place the hoverboard so the sensor boards face you.
    Pergunte ao FixBot
    Comentar
  5. Hover-1 Liberty Gyroscope Sensor Boards Replacement: passo 5, imagem 1 %32 Hover-1 Liberty Gyroscope Sensor Boards Replacement: passo 5, imagem 2 %32
    • Remove battery connector by pulling it apart.
    • Slide the rubber sheaths away from the connector on the blue, green, and yellow wires.
    • Disconnect the colored wires by pulling them apart.
    • The large colored wires connecting the sensor boards to the wheels need to match for the motor to operate correctly.
    Pergunte ao FixBot
    Comentar
  6. Hover-1 Liberty Gyroscope Sensor Boards Replacement: passo 6, imagem 1 %32 Hover-1 Liberty Gyroscope Sensor Boards Replacement: passo 6, imagem 2 %32
    • Remove the white cable from the sensor boards by disconnecting the cable on each side of the hoverboard.
    • To release the cable connector, squeeze the sides while pulling it away from the sensor board.
    Pergunte ao FixBot
    Comentar
  7. Hover-1 Liberty Gyroscope Sensor Boards Replacement: passo 7, imagem 1 %32 Hover-1 Liberty Gyroscope Sensor Boards Replacement: passo 7, imagem 2 %32
    • Remove the four 10mm screws with a Phillips #1 screwdriver.
    Pergunte ao FixBot
    Comentar
  8. Hover-1 Liberty Gyroscope Sensor Boards Replacement: passo 8, imagem 1 %32 Hover-1 Liberty Gyroscope Sensor Boards Replacement: passo 8, imagem 2 %32
    • Remove the sensor board by lifting it away from the hoverboard.
    • Repeat steps 4-8 to remove the sensor board from the other side.
    Pergunte ao FixBot
    Comentar
Conclusão
6 outras pessoas executaram este guia.
Equipe
Cal Poly, Team S13-G2, White Fall 2018 Membro de Cal Poly, Team S13-G2, White Fall 2018
CPSU-WHITE-F18S13G2
3 Membros
Autoria de 4 guias
9Comentários do guia
Where can you purchase the replacement board for the Hover-1 liberty?
Clifton Hale - Responder Compartilhar
Where do you get replacement board?
Tim Sole - Responder Compartilhar
After riding just a few times the hover board wouldn’t move. Also it has a rattle inside
Regina - Responder Compartilhar
Make this site useful by telling us where we can buy a new circuit board.
tim stoinski - Responder Compartilhar
Where do you get circuit board from.
markrichardowen - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 59
Ao todo: 10,241
