Ir para o conteúdo principal
Hover-1 Liberty Bottom Cover Replacement
O que você precisa
    1. Hover-1 Liberty Bottom Cover Replacement, Bottom Cover: passo 1, imagem 1 %32 Hover-1 Liberty Bottom Cover Replacement, Bottom Cover: passo 1, imagem 2 %32
      • Flip the hoverboard over so the labels are facing upwards.
      • Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
      Pergunte ao FixBot
      Comentar
    2. Hover-1 Liberty Bottom Cover Replacement: passo 2, imagem 1 %32 Hover-1 Liberty Bottom Cover Replacement: passo 2, imagem 2 %32
      • Remove the bottom cover by lifting it away from the hoverboard.
      • The cover on the side without the battery has two wires connecting the power button and charging port.
      Pergunte ao FixBot
      Comentar
    3. Hover-1 Liberty Bottom Cover Replacement: passo 3, imagem 1 %32 Hover-1 Liberty Bottom Cover Replacement: passo 3, imagem 2 %32 Hover-1 Liberty Bottom Cover Replacement: passo 3, imagem 3 %32
      • Remove one connector from the non-battery side circuit board.
      • Remove the next connector from the non-battery side circuit board.
      • To remove the connectors, pinch the plug and pull away from the circuit board.
      Pergunte ao FixBot
      Comentar
Conclusão
3 outras pessoas executaram este guia.
Patrick Bacon
Membro desde: 10/08/18
438 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S13-G2, White Fall 2018 Membro de Cal Poly, Team S13-G2, White Fall 2018
CPSU-WHITE-F18S13G2
3 Membros
Autoria de 4 guias
2Comentários do guia
I'm gettin nothin at all.. Charger is green.. But absolutely nothing when press the on button.. All the cables are connected.. No lights or anythin.. Can anyone help.
stemirnoff@hotmail.co.uk - Responder Compartilhar
I am getting the 5 red lights. I have followed all the instructions. Is there a site to buy the motherboards that are burned out? Is it financially worth buy both boards and replacing them?
-Christopher Fields, Network Engineer, PC Repair, Grantsville, UT
Christopher Fields - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 12
Últimos 30 dias: 48
Ao todo: 3,701
