Ir para o conteúdo principal
Hover-1 Liberty Battery Replacement
O que você precisa
    1. Hover-1 Liberty Battery Replacement, Bottom Cover: passo 1, imagem 1 %32 Hover-1 Liberty Battery Replacement, Bottom Cover: passo 1, imagem 2 %32
      • Flip the hoverboard over so the labels are facing upwards.
      • Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
      Pergunte ao FixBot
      Comentar
    2. Hover-1 Liberty Battery Replacement: passo 2, imagem 1 %32 Hover-1 Liberty Battery Replacement: passo 2, imagem 2 %32
      • Remove the bottom cover by lifting it away from the hoverboard.
      • The cover on the side without the battery has two wires connecting the power button and charging port.
      Pergunte ao FixBot
      Comentar
    3. Hover-1 Liberty Battery Replacement: passo 3, imagem 1 %32 Hover-1 Liberty Battery Replacement: passo 3, imagem 2 %32 Hover-1 Liberty Battery Replacement: passo 3, imagem 3 %32
      • Remove one connector from the non-battery side circuit board.
      • Remove the next connector from the non-battery side circuit board.
      • To remove the connectors, pinch the plug and pull away from the circuit board.
      Pergunte ao FixBot
      Comentar
    1. Hover-1 Liberty Battery Replacement, Battery: passo 4, imagem 1 %32 Hover-1 Liberty Battery Replacement, Battery: passo 4, imagem 2 %32
      • Disconnect the large red and black wire from the battery by pulling apart the connector.
      Pergunte ao FixBot
      Comentar
    2. Hover-1 Liberty Battery Replacement: passo 5, imagem 1 %32 Hover-1 Liberty Battery Replacement: passo 5, imagem 2 %32
      • Remove the four 15mm Phillips #1 screws from the bracket holding the battery in place.
      Pergunte ao FixBot
      Comentar
    3. Hover-1 Liberty Battery Replacement: passo 6, imagem 1 %32 Hover-1 Liberty Battery Replacement: passo 6, imagem 2 %32
      • Remove the bracket by pulling it upwards, away from the hoverboard.
      • You will need to move some wires aside to remove the bracket successfully.
      Pergunte ao FixBot
      Comentar
    4. Hover-1 Liberty Battery Replacement: passo 7, imagem 1 %32 Hover-1 Liberty Battery Replacement: passo 7, imagem 2 %32 Hover-1 Liberty Battery Replacement: passo 7, imagem 3 %32
      • Remove the battery by grasping the battery and hoverboard firmly and pulling apart.
      • The battery is held in place by adhesive. So, some force is required to remove it.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Patrick Bacon
Membro desde: 10/08/18
438 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S13-G2, White Fall 2018 Membro de Cal Poly, Team S13-G2, White Fall 2018
CPSU-WHITE-F18S13G2
3 Membros
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 16
Últimos 30 dias: 54
Ao todo: 3,316
