Ir para o conteúdo principal
Hover-1 Horizon Power Button Replacement
O que você precisa
  1. Hover-1 Horizon Power Button Replacement, Base Plate: passo 1, imagem 1 %32 Hover-1 Horizon Power Button Replacement, Base Plate: passo 1, imagem 2 %32
    • Remove the six 12mm Phillips #2 screws holding the base plate.
    Pergunte ao FixBot
    Comentar
  2. Hover-1 Horizon Power Button Replacement: passo 2, imagem 1 %32 Hover-1 Horizon Power Button Replacement: passo 2, imagem 2 %32
    • Remove the two 11mm Phillips #1 screws that hold the base plate to the body.
    Pergunte ao FixBot
    Comentar
  3. Hover-1 Horizon Power Button Replacement: passo 3, imagem 1 %32 Hover-1 Horizon Power Button Replacement: passo 3, imagem 2 %32 Hover-1 Horizon Power Button Replacement: passo 3, imagem 3 %32
    • Remove the base plate by lifting it up.
    • The base plate is connected to the body with wires. The wires are long enough to set the base plate to the side.
    Pergunte ao FixBot
    Comentar
  4. Hover-1 Horizon Power Button Replacement, Power Button: passo 4, imagem 1 %32
    • Reorient the Hover-1 Horizon so the base plate opens towards you.
    Pergunte ao FixBot
    Comentar
  5. Hover-1 Horizon Power Button Replacement: passo 5, imagem 1 %32 Hover-1 Horizon Power Button Replacement: passo 5, imagem 2 %32 Hover-1 Horizon Power Button Replacement: passo 5, imagem 3 %32
    • Remove the connector by squeezing the tab and lifting up.
    Pergunte ao FixBot
    Comentar
  6. Hover-1 Horizon Power Button Replacement: passo 6, imagem 1 %32 Hover-1 Horizon Power Button Replacement: passo 6, imagem 2 %32 Hover-1 Horizon Power Button Replacement: passo 6, imagem 3 %32
    • Remove the second connector by squeezing the tab and pulling up.
    Pergunte ao FixBot
    Comentar
  7. Hover-1 Horizon Power Button Replacement: passo 7, imagem 1 %32 Hover-1 Horizon Power Button Replacement: passo 7, imagem 2 %32 Hover-1 Horizon Power Button Replacement: passo 7, imagem 3 %32
    • Unscrew the power button by holding the front and twisting the back nut counter-clockwise.
    • Push the power button through the base plate to remove.
    • A hot air gun may need to be used to remove the adhesive connecting the base plate to the power button.
    Pergunte ao FixBot
    Comentar
Conclusão
Christina Fong
Membro desde: 10/08/18
165 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S13-G6, White Fall 2018 Membro de Cal Poly, Team S13-G6, White Fall 2018
CPSU-WHITE-F18S13G6
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 25
Ao todo: 872
