Ir para o conteúdo principal
Hover-1 Horizon Left Balancing Sensor Replacement
O que você precisa
  1. Hover-1 Horizon Left Balancing Sensor Replacement, Base Plate: passo 1, imagem 1 %32 Hover-1 Horizon Left Balancing Sensor Replacement, Base Plate: passo 1, imagem 2 %32
    • Remove the six 12mm Phillips #2 screws holding the base plate.
    Pergunte ao FixBot
    Comentar
  2. Hover-1 Horizon Left Balancing Sensor Replacement: passo 2, imagem 1 %32 Hover-1 Horizon Left Balancing Sensor Replacement: passo 2, imagem 2 %32
    • Remove the two 11mm Phillips #1 screws that hold the base plate to the body.
    Pergunte ao FixBot
    Comentar
  3. Hover-1 Horizon Left Balancing Sensor Replacement: passo 3, imagem 1 %32 Hover-1 Horizon Left Balancing Sensor Replacement: passo 3, imagem 2 %32 Hover-1 Horizon Left Balancing Sensor Replacement: passo 3, imagem 3 %32
    • Remove the base plate by lifting it up.
    • The base plate is connected to the body with wires. The wires are long enough to set the base plate to the side.
    Pergunte ao FixBot
    Comentar
  4. Hover-1 Horizon Left Balancing Sensor Replacement, Left Gyroscope Sensor Board: passo 4, imagem 1 %32 Hover-1 Horizon Left Balancing Sensor Replacement, Left Gyroscope Sensor Board: passo 4, imagem 2 %32 Hover-1 Horizon Left Balancing Sensor Replacement, Left Gyroscope Sensor Board: passo 4, imagem 3 %32
    • Remove the two connectors on either side of the board by lifting the tab and pulling out.
    • Remove the connector in the middle of the board by squeezing the tab and pulling up.
    Pergunte ao FixBot
    Comentar
  5. Hover-1 Horizon Left Balancing Sensor Replacement: passo 5, imagem 1 %32 Hover-1 Horizon Left Balancing Sensor Replacement: passo 5, imagem 2 %32
    • Remove the four 11mm Phillips #1 screws that hold the cover on.
    Pergunte ao FixBot
    Comentar
  6. Hover-1 Horizon Left Balancing Sensor Replacement: passo 6, imagem 1 %32 Hover-1 Horizon Left Balancing Sensor Replacement: passo 6, imagem 2 %32 Hover-1 Horizon Left Balancing Sensor Replacement: passo 6, imagem 3 %32
    • Remove the four 11mm Phillips #1 screws that attach the gyroscope board to the mount.
    • Lift the board to reveal the connections on the bottom.
    Pergunte ao FixBot
    Comentar
  7. Hover-1 Horizon Left Balancing Sensor Replacement: passo 7, imagem 1 %32 Hover-1 Horizon Left Balancing Sensor Replacement: passo 7, imagem 2 %32
    • Remove the middle connector by squeezing the top of the tab and pulling up.
    Pergunte ao FixBot
    Comentar
  8. Hover-1 Horizon Left Balancing Sensor Replacement: passo 8, imagem 1 %32 Hover-1 Horizon Left Balancing Sensor Replacement: passo 8, imagem 2 %32 Hover-1 Horizon Left Balancing Sensor Replacement: passo 8, imagem 3 %32
    • Remove the four 12mm Phillips #2 screws that hold the motherboard to the base.
    • Pull the motherboard away from the gyroscope by grabbing it with two hands and pulling it to the right .
    Pergunte ao FixBot
    Comentar
  9. Hover-1 Horizon Left Balancing Sensor Replacement: passo 9, imagem 1 %32 Hover-1 Horizon Left Balancing Sensor Replacement: passo 9, imagem 2 %32 Hover-1 Horizon Left Balancing Sensor Replacement: passo 9, imagem 3 %32
    • Unclip the black connector by squeezing both sides and pulling them apart.
    Pergunte ao FixBot
    Comentar
  10. Hover-1 Horizon Left Balancing Sensor Replacement, Left Balancing Sensors: passo 10, imagem 1 %32 Hover-1 Horizon Left Balancing Sensor Replacement, Left Balancing Sensors: passo 10, imagem 2 %32 Hover-1 Horizon Left Balancing Sensor Replacement, Left Balancing Sensors: passo 10, imagem 3 %32
    • Remove the three 10 mm Phillips #1 screws connecting the balance sensor to the hoverboard.
    • The balance sensor tabs are made of sensitive rubber. Screw them back on slowly, and do not over-tighten.
    Pergunte ao FixBot
    Comentar
  11. Hover-1 Horizon Left Balancing Sensor Replacement: passo 11, imagem 1 %32 Hover-1 Horizon Left Balancing Sensor Replacement: passo 11, imagem 2 %32
    • Remove the sensor tab by carefully lifting it away from the hoverboard.
    Pergunte ao FixBot
    Comentar
Conclusão
Jesus
Membro desde: 10/08/18
85 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S13-G6, White Fall 2018 Membro de Cal Poly, Team S13-G6, White Fall 2018
CPSU-WHITE-F18S13G6
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 33
Ao todo: 1,577
