Ir para o conteúdo principal
Hover-1 H1 Power Button Replacement
O que você precisa
  1. Hover-1 H1 Power Button  Replacement, Bottom Shell: passo 1, imagem 1 %32
    • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    Pergunte ao FixBot
    Comentar
  2. Hover-1 H1 Power Button  Replacement: passo 2, imagem 1 %32
    • Puncture the two black stickers by using the tip of a screwdriver.
    • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    Pergunte ao FixBot
    Comentar
  3. Hover-1 H1 Power Button  Replacement: passo 3, imagem 1 %32 Hover-1 H1 Power Button  Replacement: passo 3, imagem 2 %32
    • Lift each side of the bottom shell by pulling up.
    • When lifting the shell, take care to not tear any cables from their connectors.
    Pergunte ao FixBot
    Comentar
  4. Hover-1 H1 Power Button  Replacement: passo 4, imagem 1 %32
    • Unplug the battery by pulling gently on both sides of the orange connector.
    Pergunte ao FixBot
    Comentar
  5. Hover-1 H1 Power Button  Replacement, Power Button: passo 5, imagem 1 %32
    • Unplug the power button connector by pinching the tab on the front and pulling directly upwards.
    • Pull the cable through the center section of the hoverboard.
    • For reassembly, you will have to feed the cable back through the center section. This can be done using a rigid wire or cable.
    Pergunte ao FixBot
    Comentar
  6. Hover-1 H1 Power Button  Replacement: passo 6, imagem 1 %32 Hover-1 H1 Power Button  Replacement: passo 6, imagem 2 %32
    • Using an adjustable wrench, remove the nut on the back of the power button by rotating the nut counterclockwise.
    Pergunte ao FixBot
    Comentar
  7. Hover-1 H1 Power Button  Replacement: passo 7, imagem 1 %32
    • Pull the power button through the hole in the shell.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team S17-G6, White Fall 2018 Membro de Cal Poly, Team S17-G6, White Fall 2018
CPSU-WHITE-F18S17G6
4 Membros
Autoria de 9 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 44
Ao todo: 4,066
