Ir para o conteúdo principal
Hover-1 H1 LED Headlight Replacement
O que você precisa
  1. Hover-1 H1 LED Headlight Replacement, Bottom Shell: passo 1, imagem 1 %32
    • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    Pergunte ao FixBot
    Comentar
  2. Hover-1 H1 LED Headlight Replacement: passo 2, imagem 1 %32
    • Puncture the two black stickers by using the tip of a screwdriver.
    • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    Pergunte ao FixBot
    Comentar
  3. Hover-1 H1 LED Headlight Replacement: passo 3, imagem 1 %32 Hover-1 H1 LED Headlight Replacement: passo 3, imagem 2 %32
    • Lift each side of the bottom shell by pulling up.
    • When lifting the shell, take care to not tear any cables from their connectors.
    Pergunte ao FixBot
    Comentar
  4. Hover-1 H1 LED Headlight Replacement: passo 4, imagem 1 %32
    • Unplug the battery by pulling gently on both sides of the orange connector.
    Pergunte ao FixBot
    Comentar
  5. Hover-1 H1 LED Headlight Replacement, LED Headlights: passo 5, imagem 1 %32
    • Unplug the lights from the battery by pulling gently on both sides of the black connector attached to the white wires.
    Pergunte ao FixBot
    Comentar
  6. Hover-1 H1 LED Headlight Replacement: passo 6, imagem 1 %32
    • Remove the vertical light from the shell by using your hands to pull it free from the surrounding shell.
    Pergunte ao FixBot
    Comentar
  7. Hover-1 H1 LED Headlight Replacement: passo 7, imagem 1 %32
    • Remove two 8mm screws using a Phillips #0 screwdriver to rotate the screws counterclockwise.
    • Remove the horizontal light by using your fingers to pull the light up out of the shell.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team S17-G6, White Fall 2018 Membro de Cal Poly, Team S17-G6, White Fall 2018
CPSU-WHITE-F18S17G6
4 Membros
Autoria de 9 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 25
Ao todo: 1,703
