Ir para o conteúdo principal
Hover-1 Eagle Throttle/Brake Lever Replacement
O que você precisa
  1. Hover-1 Eagle Throttle/Brake Lever Replacement, Throttle/Brake Lever: passo 1, imagem 1 %32 Hover-1 Eagle Throttle/Brake Lever Replacement, Throttle/Brake Lever: passo 1, imagem 2 %32 Hover-1 Eagle Throttle/Brake Lever Replacement, Throttle/Brake Lever: passo 1, imagem 3 %32
    • Unscrew the scooter handle.
    • The scooter handles are left-handed or reverse threaded, so twist clockwise to remove them.
  2. Hover-1 Eagle Throttle/Brake Lever Replacement: passo 2, imagem 1 %32 Hover-1 Eagle Throttle/Brake Lever Replacement: passo 2, imagem 2 %32 Hover-1 Eagle Throttle/Brake Lever Replacement: passo 2, imagem 3 %32
    • Push back the fastening clips by wedging the plastic spudger between the clip and the throttle handle.
    • Insert iFixit opening picks between each fastening clip and the throttle handle to prevent re-fastening.
    • Pull the throttle lever off gently by pulling towards you.
    • The spring housed in the handle can sometimes send the lever flying. Maintain a firm grip on the throttle lever.
  3. Hover-1 Eagle Throttle/Brake Lever Replacement: passo 3, imagem 1 %32 Hover-1 Eagle Throttle/Brake Lever Replacement: passo 3, imagem 2 %32 Hover-1 Eagle Throttle/Brake Lever Replacement: passo 3, imagem 3 %32
    • To reassemble, insert the spring into the placement hole, housed inside the throttle handle. Insert the other end of the spring into the placement hole inside the throttle body housing.
  4. Hover-1 Eagle Throttle/Brake Lever Replacement: passo 4, imagem 1 %32 Hover-1 Eagle Throttle/Brake Lever Replacement: passo 4, imagem 2 %32 Hover-1 Eagle Throttle/Brake Lever Replacement: passo 4, imagem 3 %32
    • Twist the throttle lever back to its original orientation by rotating it to the left.
    • Apply pressure to the throttle handle until you hear the fastening clips take hold the of the throttle lever.
    • Make sure the throttle lever is fully inserted and flush with the display throttle body.
  5. Hover-1 Eagle Throttle/Brake Lever Replacement: passo 5, imagem 1 %32 Hover-1 Eagle Throttle/Brake Lever Replacement: passo 5, imagem 2 %32 Hover-1 Eagle Throttle/Brake Lever Replacement: passo 5, imagem 3 %32
    • Reattach the scooter handle.
    • Make sure to twist the handles counterclockwise to tighten.
Linha de Chegada
5 outras pessoas executaram este guia.
Andrew Gaskell
Membro desde: 01/23/20
1.137 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S1-G2, White Winter 2020 Membro de Cal Poly, Team S1-G2, White Winter 2020
CPSU-WHITE-W20S1G2
4 Membros
Autoria de 6 guias
24Comentários do guia
Great detail……….. Where can I buy the replacement part (throttle) the company hover1 isn't answering me and they don't have this part on their website. Thanks
hanjna76 - Responder
Im needed a throttle did anyone have any luck?
rodarte_amanda1992 -
Where do I buy the part where do I get it please let me know The brake lever
poorbubbaa - Responder
Necesito acelerador y no lo encuentro.
Josue Villanueva - Responder
I cant squeeze the spudger and the pick between this and the spudger broke…what the!!!
Cheri Rael - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 18
Últimos 30 dias: 108
Ao todo: 17,171
