Ir para o conteúdo principal
Hover-1 Eagle LED Headlight Replacement
O que você precisa
  1. Hover-1 Eagle LED Headlight Replacement, LED Headlight: passo 1, imagem 1 %32 Hover-1 Eagle LED Headlight Replacement, LED Headlight: passo 1, imagem 2 %32 Hover-1 Eagle LED Headlight Replacement, LED Headlight: passo 1, imagem 3 %32
    • Remove the four screws from the bottom side of the display housing using a Phillips #2 screwdriver.
  2. Hover-1 Eagle LED Headlight Replacement: passo 2, imagem 1 %32 Hover-1 Eagle LED Headlight Replacement: passo 2, imagem 2 %32 Hover-1 Eagle LED Headlight Replacement: passo 2, imagem 3 %32
    • Carefully remove the top of the housing containing the display screen.
    • Remove the top of the housing slowly to avoid damaging the wires.
  3. Hover-1 Eagle LED Headlight Replacement: passo 3, imagem 1 %32 Hover-1 Eagle LED Headlight Replacement: passo 3, imagem 2 %32
    • Slide the LED light cover upwards out of the display housing
    • Be gentle when removing the LED light cover to avoid damaging the LED's connecting wires.
    • The LED circuit board should slide out with the LED light cover.
    • To reassemble, align the prongs of the LED cover with the holes in the LED circuit board.
  4. Hover-1 Eagle LED Headlight Replacement: passo 4, imagem 1 %32 Hover-1 Eagle LED Headlight Replacement: passo 4, imagem 2 %32 Hover-1 Eagle LED Headlight Replacement: passo 4, imagem 3 %32
    • Using a soldering iron, desolder the black and red wires from the LED circuit board.
    • To reassemble, solder the same black and red wires onto the new LED circuit board.
Conclusão
4 outras pessoas executaram este guia.
Andrew Gaskell
Membro desde: 01/23/20
1.137 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S1-G2, White Winter 2020 Membro de Cal Poly, Team S1-G2, White Winter 2020
CPSU-WHITE-W20S1G2
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 25
Ao todo: 1,369
