Ir para o conteúdo principal
Hover-1 Coast Power Button Spring Replacement
O que você precisa
    1. Hover-1 Coast Power Button Spring Replacement, Board Battery: passo 1, imagem 1 %32 Hover-1 Coast Power Button Spring Replacement, Board Battery: passo 1, imagem 2 %32 Hover-1 Coast Power Button Spring Replacement, Board Battery: passo 1, imagem 3 %32
      • To remove the battery on the Hover-1 Coast, you must uncover the screws on the top of the board.
      • Using a pick tool, puncture the grip tape and expose the screws.
      • Loosen all four 1" screws using a Phillips #1 screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Hover-1 Coast Power Button Spring Replacement: passo 2, imagem 1 %32 Hover-1 Coast Power Button Spring Replacement: passo 2, imagem 2 %32 Hover-1 Coast Power Button Spring Replacement: passo 2, imagem 3 %32
      • Now pull the black protective cover off the board.
      • Locate the battery.
      Pergunte ao FixBot
      Comentar
    3. Hover-1 Coast Power Button Spring Replacement: passo 3, imagem 1 %32 Hover-1 Coast Power Button Spring Replacement: passo 3, imagem 2 %32 Hover-1 Coast Power Button Spring Replacement: passo 3, imagem 3 %32
      • The battery is connected by these two sets of wires.
      • Remove the yellow wire first by pulling the two wires gently in opposite directions.
      • Now pull apart the black wire by gently pulling the two wires in opposite directions.
      Pergunte ao FixBot
      Comentar
    4. Hover-1 Coast Power Button Spring Replacement: passo 4, imagem 1 %32 Hover-1 Coast Power Button Spring Replacement: passo 4, imagem 2 %32 Hover-1 Coast Power Button Spring Replacement: passo 4, imagem 3 %32
      • Once the battery has been disconnected, gently pry the battery upward.
      • It is important to use a plastic opening tool to avoid puncturing the battery.
      • Once the battery is freed, remove it with your hands.
      • The battery is glued to the case and will require some effort to remove.
      Pergunte ao FixBot
      Comentar
    1. Hover-1 Coast Power Button Spring Replacement, Power Button Spring: passo 5, imagem 1 %32 Hover-1 Coast Power Button Spring Replacement, Power Button Spring: passo 5, imagem 2 %32 Hover-1 Coast Power Button Spring Replacement, Power Button Spring: passo 5, imagem 3 %32
      • Using the Phillips #1 screwdriver, loosen the two screws and place the power button somewhere safe.
      Pergunte ao FixBot
      Comentar
    2. Hover-1 Coast Power Button Spring Replacement: passo 6, imagem 1 %32 Hover-1 Coast Power Button Spring Replacement: passo 6, imagem 2 %32
      • Remove the unwanted spring and place your new spring back into the hole.
      Pergunte ao FixBot
      Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 33
Ao todo: 765
