Ir para o conteúdo principal
Hover-1 Chrome Left Gyroscope Sensor Board Replacement
O que você precisa
    1. Hover-1 Chrome Left Gyroscope Sensor Board Replacement, Hover-1 Chrome Disassembly: passo 1, imagem 1 %32
      • Flip the Hover-1 Chrome upside down.
      • Use a Phillips #2 screwdriver to remove the fourteen 14 mm screws from the bottom of the Hover-1.
      • Break the two black tape circles, and remove the two 15 mm Phillips screws underneath.
      Pergunte ao FixBot
      Comentar
    2. Hover-1 Chrome Left Gyroscope Sensor Board Replacement: passo 2, imagem 1 %32
      • Lift the shell without the speaker grille and unplug the battery.
      Pergunte ao FixBot
      Comentar
    3. Hover-1 Chrome Left Gyroscope Sensor Board Replacement: passo 3, imagem 1 %32 Hover-1 Chrome Left Gyroscope Sensor Board Replacement: passo 3, imagem 2 %32
      • Lift the shell with the speaker grille.
      • Unplug the speaker.
      • Unplug the LEDs.
      • Unplug the power button
      • Unplug the charging port.
      Pergunte ao FixBot
      Comentar
    1. Hover-1 Chrome Left Gyroscope Sensor Board Replacement, Left Gyroscope Sensor Board: passo 4, imagem 1 %32 Hover-1 Chrome Left Gyroscope Sensor Board Replacement, Left Gyroscope Sensor Board: passo 4, imagem 2 %32 Hover-1 Chrome Left Gyroscope Sensor Board Replacement, Left Gyroscope Sensor Board: passo 4, imagem 3 %32
      • Disconnect the speaker cable.
      • Disconnect the cable that travels to the other sensor board.
      Pergunte ao FixBot
      Comentar
    2. Hover-1 Chrome Left Gyroscope Sensor Board Replacement: passo 5, imagem 1 %32 Hover-1 Chrome Left Gyroscope Sensor Board Replacement: passo 5, imagem 2 %32 Hover-1 Chrome Left Gyroscope Sensor Board Replacement: passo 5, imagem 3 %32
      • Disconnect the smaller connector midway on the cable.
      • Disconnect the larger connector midway on the cable.
      Pergunte ao FixBot
      Comentar
    3. Hover-1 Chrome Left Gyroscope Sensor Board Replacement: passo 6, imagem 1 %32
      • Remove the four 12mm Phillips #2 screws securing the sensor board.
      Pergunte ao FixBot
      Comentar
    4. Hover-1 Chrome Left Gyroscope Sensor Board Replacement: passo 7, imagem 1 %32 Hover-1 Chrome Left Gyroscope Sensor Board Replacement: passo 7, imagem 2 %32
      • Locate the five solder locations on the underside of the gyroscope sensor board.
      • Plug in soldering iron and wait for the tip tip to reach its target temperature.
      • Rest the tip of the iron on the solder and wait for the solder to melt. The wire will drop out of the sensor board.
      • Be aware of where the tip of the soldering iron is at ALL times. Put on safety glasses before picking up the soldering iron. Turn on a fan and face it towards the device to vent harmful fumes away from the solderers face.
      Pergunte ao FixBot
      Comentar
Conclusão
Nick McGuire
Membro desde: 10/08/18
551 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team S4-G1, White Fall 2018 Membro de Cal Poly, Team S4-G1, White Fall 2018
CPSU-WHITE-F18S4G1
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 31
Ao todo: 1,563
