Ir para o conteúdo principal
Hover-1 Charger LED Headlight Replacement
O que você precisa
  1. Hover-1 Charger LED Headlight Replacement, Unplugging the Battery: passo 1, imagem 1 %32 Hover-1 Charger LED Headlight Replacement, Unplugging the Battery: passo 1, imagem 2 %32
    • Flip the hoverboard over so that the warning label is facing up.
    • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
    • Remove the four 10 mm screws with a Phillips #2 screwdriver.
    • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
  2. Hover-1 Charger LED Headlight Replacement: passo 2, imagem 1 %32
    • Pull the right cover away from the hoverboard to expose the battery.
  3. Hover-1 Charger LED Headlight Replacement: passo 3, imagem 1 %32 Hover-1 Charger LED Headlight Replacement: passo 3, imagem 2 %32
    • Disconnect the two pronged black and yellow cable.
  4. Hover-1 Charger LED Headlight Replacement: passo 4, imagem 1 %32
    • Pull the left cover away from the hoverboard.
  5. Hover-1 Charger LED Headlight Replacement: passo 5, imagem 1 %32 Hover-1 Charger LED Headlight Replacement: passo 5, imagem 2 %32
    • Disconnect the two pronged black and yellow cable. The battery is now fully disconnected.
  6. Hover-1 Charger LED Headlight Replacement, LED Headlight: passo 6, imagem 1 %32 Hover-1 Charger LED Headlight Replacement, LED Headlight: passo 6, imagem 2 %32
    • Remove the black and red two pin connector from the circuitboard.
  7. Hover-1 Charger LED Headlight Replacement: passo 7, imagem 1 %32 Hover-1 Charger LED Headlight Replacement: passo 7, imagem 2 %32
    • Remove the two 12mm screws holding the LED to the front cover with a Phillips #2 screwdriver.
    • Our Hoverboard was missing a screw in the LED housing. Yours may or may not be missing screws as well.
  8. Hover-1 Charger LED Headlight Replacement: passo 8, imagem 1 %32
    • With the wire unplugged and screws removed, you can now safely seperate the LED from the Hoverboard.
Conclusão
Benji Forest
Membro desde: 10/10/19
266 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S12-G1, Regan Fall 2019 Membro de Cal Poly, Team S12-G1, Regan Fall 2019
CPSU-REGAN-F19S12G1
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 226
