Ir para o conteúdo principal
Hott T725-8G Battery Replacement
O que você precisa
  1. Hott T725-8G Battery Replacement, Back Panel: passo 1, imagem 1 %32
    • Remove the back of the device using the Plastic Opening tool by placing it between the front and back panel and gently prying them apart.
    Pergunte ao FixBot
    Comentar
  2. Hott T725-8G Battery Replacement: passo 2, imagem 1 %32
    • Once the Plastic Opening tool has separated the halves, use your hands to pull them completely apart.
    • Be careful when doing this - the speaker is attached to the back panel and has wires running to the motherboard in the front panel.
    Pergunte ao FixBot
    Comentar
  3. Hott T725-8G Battery Replacement: passo 3, imagem 1 %32
    • Carefully dislodge the speaker from the back panel.
    Pergunte ao FixBot
    Comentar
  4. Hott T725-8G Battery Replacement, Battery: passo 4, imagem 1 %32
    • Remove the yellow tape holding the wire connecting the battery to the motherboard with your fingers.
    Pergunte ao FixBot
    Comentar
  5. Hott T725-8G Battery Replacement: passo 5, imagem 1 %32
    • Use your fingers to separate the ribbon wire from the battery and the back of the display.
    Pergunte ao FixBot
    Comentar
  6. Hott T725-8G Battery Replacement: passo 6, imagem 1 %32
    • Use your fingers to remove more yellow tape holding down the wire connecting the battery to the motherboard.
    Pergunte ao FixBot
    Comentar
  7. Hott T725-8G Battery Replacement: passo 7, imagem 1 %32
    • You can check one of the connection points between the battery and the motherboard to see if it is firmly connected (which it should be) using the plastic Spudger. It is not necessary to remove this wire to replace the battery.
    Pergunte ao FixBot
    Comentar
  8. Hott T725-8G Battery Replacement: passo 8, imagem 1 %32
    • Use a Plastic Spudger to separate the adhesive side of the battery from the back of the display.
    • Avoid using metal when working with batteries.
    • The adhesive is extremely sticky, but will separate. Ensure that the battery doesn't bend or fold while removing it.
    Pergunte ao FixBot
    Comentar
  9. Hott T725-8G Battery Replacement: passo 9, imagem 1 %32
    • You may use the plastic Spudger to separate the connections between the battery and motherboard. The new battery is now ready to be soldered on.
    Pergunte ao FixBot
    Comentar
Conclusão
Emma Carroll
Membro desde: 10/20/16
220 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 6-2, Martin Fall 2016 Membro de UMass Dartmouth, Team 6-2, Martin Fall 2016
UMASSD-MARTIN-F16S6G2
3 Membros
Autoria de 11 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 24
Ao todo: 673
