Ir para o conteúdo principal
Hot Wheels AI Intelligent Race System Wire Replacement
O que você precisa
  1. Hot Wheels AI Intelligent Race System Wire Replacement, Controller Wires: passo 1, imagem 1 %32
    • Remove the six screws located on the back of the controller using a JIS #1 screwdriver.
    Pergunte ao FixBot
    Comentar
  2. Hot Wheels AI Intelligent Race System Wire Replacement: passo 2, imagem 1 %32
    • Pop the front of the controller casing from the back and carefully lay the controller out with circuits exposed.
    Pergunte ao FixBot
    Comentar
  3. Hot Wheels AI Intelligent Race System Wire Replacement: passo 3, imagem 1 %32
    • Check all wires for disconnections. They are color coated red, black, orange, and yellow. If wires are disconnected they can easily be reinserted as shown in photos.
    • Some wires may require soldering which can be done with a soldering iron. The wire marked in red may need to be soldered but can sometimes be reattached.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 36
Ao todo: 760
