Ir para o conteúdo principal
Hot Wheels AI Intelligent Race System Controller Transmitter Replacement
O que você precisa
  1. Hot Wheels AI Intelligent Race System Controller Transmitter Replacement, Controller Transmitter: passo 1, imagem 1 %32
    • Locate and remove the six screws on the back of the controller. Remove screws with a #J1 Philips head screwdriver.
    Pergunte ao FixBot
    Comentar
  2. Hot Wheels AI Intelligent Race System Controller Transmitter Replacement: passo 2, imagem 1 %32
    • With the controller facing down remove the top casing from the bottom. Do this by popping the casing lose which will expose the inside circuits.
    Pergunte ao FixBot
    Comentar
  3. Hot Wheels AI Intelligent Race System Controller Transmitter Replacement: passo 3, imagem 1 %32
    • With the circuits exposed locate the transmitter at the top of the controller. It is green hue in comparison to the rest of the blue circuits. Check the transmitter for damage or disconnected wires.
    Pergunte ao FixBot
    Comentar
  4. Hot Wheels AI Intelligent Race System Controller Transmitter Replacement: passo 4, imagem 1 %32
    • If transmitter has broken or has disconnected wires it may need replacement. Wires can easily break loose from the transmitter. The wires can easily be reinserted by sticking the wire back into its original slot.
    Pergunte ao FixBot
    Comentar
  5. Hot Wheels AI Intelligent Race System Controller Transmitter Replacement: passo 5, imagem 1 %32
    • If the transmitter is damaged, replace it by sliding the circuit down from its slot. Check for damage or burned out circuit.
    • Replace transmitter circuit with a new one by reinserting it into the original slot.
    Pergunte ao FixBot
    Comentar
Conclusão
1Comentário do guia
Give the part numbers so we can source the circuits and change the devices if needed. Also can anyone extract the rim? I believe the rim being used is way low quality.
Luis Vitorio Cargnini - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 9
Últimos 30 dias: 51
Ao todo: 1,424
