Ir para o conteúdo principal
Hoover Power Path Pro Advanced Power Switch Replacement
O que você precisa
    1. Hoover Power Path Pro Advanced Power Switch Replacement, Power Switch: passo 1, imagem 1 %32
      • Remove the lower brushroll from the bottom of the cleaner.
      Pergunte ao FixBot
      Comentar
    2. Hoover Power Path Pro Advanced Power Switch Replacement: passo 2, imagem 1 %32
      • Use a long #2 Philips head to remove the 8 numbered screws on the bottom of the cleaner (They will also be indicated on the bottom of the vacuum).
      Pergunte ao FixBot
      Comentar
    3. Hoover Power Path Pro Advanced Power Switch Replacement: passo 3, imagem 1 %32 Hoover Power Path Pro Advanced Power Switch Replacement: passo 3, imagem 2 %32
      • Pull the red handle to remove the front suction unit from the cleaner.
      Pergunte ao FixBot
      Comentar
    4. Hoover Power Path Pro Advanced Power Switch Replacement: passo 4, imagem 1 %32
      • Unscrew the hose by using a Phillips #2 to detach it from the top cover of the cleaner.
      Pergunte ao FixBot
      Comentar
    5. Hoover Power Path Pro Advanced Power Switch Replacement: passo 5, imagem 1 %32 Hoover Power Path Pro Advanced Power Switch Replacement: passo 5, imagem 2 %32
      • Push down on the handle release button. Lift the edge of top cover connected to this button.
      • Repeat the above step for the "On/Off" button.
      • Pull entire top cover off.
      • Caution: when pulling the handle release button, make sure the top of the cleaner does not fall.
      Pergunte ao FixBot
      Comentar
    6. Hoover Power Path Pro Advanced Power Switch Replacement: passo 6, imagem 1 %32
      • Remove the "On/Off" cap by pulling it upwards with caution.
      Pergunte ao FixBot
      Comentar
    7. Hoover Power Path Pro Advanced Power Switch Replacement: passo 7, imagem 1 %32
      • Use a long #2 Philips head to remove the two screws from the arched grey piece.
      Pergunte ao FixBot
      Comentar
    8. Hoover Power Path Pro Advanced Power Switch Replacement: passo 8, imagem 1 %32 Hoover Power Path Pro Advanced Power Switch Replacement: passo 8, imagem 2 %32
      • Pull out the red power the red power switch.
      Pergunte ao FixBot
      Comentar
Conclusão
4 outras pessoas executaram este guia.
Equipe
Cal Poly, Team S16-G5, Banghart Winter 2018 Membro de Cal Poly, Team S16-G5, Banghart Winter 2018
CPSU-BANGHART-W18S16G5
5 Membros
Autoria de 54 guias
3Comentários do guia
What is the part number?
martahayner - Responder Compartilhar
Thanks so much!!
debmccrimm - Responder Compartilhar
you have to test the switch, mine tested ok which led me to the fuse between the motor and switch. It was bad, parts warehouse part # 440004065 does the trick.
frank - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 49
Ao todo: 4,359
