Ir para o conteúdo principal
Hoover Power Path Pro Advanced Hose Replacement
O que você precisa
  1. Hoover Power Path Pro Advanced Hose Replacement, Brush Roller: passo 1, imagem 1 %32 Hoover Power Path Pro Advanced Hose Replacement, Brush Roller: passo 1, imagem 2 %32
    • Unplug the vacuum cleaner from the wall outlet before starting. Make sure the water tanks are empty.
    • Lay the cleaner down horizontally with its wheels closest to the floor.
    Pergunte ao FixBot
    Comentar
  2. Hoover Power Path Pro Advanced Hose Replacement: passo 2, imagem 1 %32 Hoover Power Path Pro Advanced Hose Replacement: passo 2, imagem 2 %32
    • Hold the lower brush roll with both hands and pull outwards until it is detached.
    Pergunte ao FixBot
    Comentar
  3. Hoover Power Path Pro Advanced Hose Replacement: passo 3, imagem 1 %32
    • Unscrew the 6 marked screws using a Phillips #2 head screwdriver.
    • Remove the brush roller.
    Pergunte ao FixBot
    Comentar
  4. Hoover Power Path Pro Advanced Hose Replacement, Hose: passo 4, imagem 1 %32
    • Use a long #2 Philips head screwdriver to remove the 8 numbered screws on the bottom of the cleaner.
    • They will also be indicated on the bottom of the vacuum.
    Pergunte ao FixBot
    Comentar
  5. Hoover Power Path Pro Advanced Hose Replacement: passo 5, imagem 1 %32 Hoover Power Path Pro Advanced Hose Replacement: passo 5, imagem 2 %32
    • Pull the red handle shown to remove the front suction unit from the cleaner.
    Pergunte ao FixBot
    Comentar
  6. Hoover Power Path Pro Advanced Hose Replacement: passo 6, imagem 1 %32
    • Unscrew the Phillips #2 screw at the bottom of the hose.
    Pergunte ao FixBot
    Comentar
  7. Hoover Power Path Pro Advanced Hose Replacement: passo 7, imagem 1 %32
    • Grab the attachment at tip of the hose and unscrew it. Pull outwards on the hose until completely removed.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Equipe
Cal Poly, Team S16-G5, Banghart Winter 2018 Membro de Cal Poly, Team S16-G5, Banghart Winter 2018
CPSU-BANGHART-W18S16G5
5 Membros
Autoria de 20 guias
4Comentários do guia
Where can I find this replacement hose?
Jennifer - Responder Compartilhar
Complete waste of $$, won’t pick up water unless you apply about 40 lbs of downward force on the %#*@ thing, I tried all the trouble shooting tips, no change, maybe used 3 times. The attachment same thing nada. Basically a toy.
Leigh Robert Smith - Responder Compartilhar
Where can I purchase the lower hose?
Eryk H. - Responder Compartilhar
I've been trying to find the hose for mine for two years now I even called hoover and they tell me it's unavailable maybe I need to find a Hoover scrap yard lol if anyone knows where I can get one please let me know via email at jefferyalger1959@gmail.com
Jeffery Alger - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 28
Ao todo: 5,113
