Ir para o conteúdo principal
Hoover LiNX The Nozzle Prongs Replacement
O que você precisa
  1. Hoover LiNX The Nozzle Prongs Replacement, Replace The Motor: passo 1, imagem 1 %32
    • Detach the rolling assembly from the body by pushing the button found at the base.
  2. Hoover LiNX The Nozzle Prongs Replacement: passo 2, imagem 1 %32
    • Remove the seven 7.5mm Phillips #1 screws from the brush retainer.
  3. Hoover LiNX The Nozzle Prongs Replacement: passo 3, imagem 1 %32 Hoover LiNX The Nozzle Prongs Replacement: passo 3, imagem 2 %32
    • Remove the brush and retainer from the rolling assembly.
    • The brush will need to be disconnected from the belt.
  4. Hoover LiNX The Nozzle Prongs Replacement: passo 4, imagem 1 %32
    • Remove the eight 4mm Phillips #1 screws from the bottom panel.
  5. Hoover LiNX The Nozzle Prongs Replacement: passo 5, imagem 1 %32
    • Remove the bottom panel.
  6. Hoover LiNX The Nozzle Prongs Replacement: passo 6, imagem 1 %32
    • Remove the motor.
  7. Hoover LiNX The Nozzle Prongs Replacement, The Nozzle Prongs: passo 7, imagem 1 %32
    • Remove the two 7.5mm Phillips #1 screws from the main body.
  8. Hoover LiNX The Nozzle Prongs Replacement: passo 8, imagem 1 %32
    • Remove the black covering from the air tube.
  9. Hoover LiNX The Nozzle Prongs Replacement: passo 9, imagem 1 %32
    • Slide the prongs out through their channels.
  10. Hoover LiNX The Nozzle Prongs Replacement: passo 10, imagem 1 %32 Hoover LiNX The Nozzle Prongs Replacement: passo 10, imagem 2 %32
    • Remove the angled neck and feed the prongs out through their channels.
  11. Hoover LiNX The Nozzle Prongs Replacement: passo 11, imagem 1 %32 Hoover LiNX The Nozzle Prongs Replacement: passo 11, imagem 2 %32
    • Replace the prongs.
Conclusão
Sara Vlhova
Membro desde: 01/25/18
541 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S7-G4, Passmore Spring 2018 Membro de USF Tampa, Team S7-G4, Passmore Spring 2018
USFT-PASSMORE-S18S7G4
4 Membros
Autoria de 12 guias
2 comentários
How do I get to the receivers for the prongs? They appear to be too loose to make a connection and i have not been able to get into the body to tighten. Is there another way to improve this connection?
Robert L Worthing - Responder
Thank you for asking ifixit your 11/1018 question. I’ve been trying to disassemble the body to get at the receiver(s)/socket(s) for those prongs for days. And ifixit, please, have you got a picture of the routing of the brush motor wires from the motor through the rolling assembly, the swiveling universal joint, and along the back of the airtube?
donwesel - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Ao todo: 1,881
