Ir para o conteúdo principal
Honeytone N-10 Mini Amp Speaker Replacement
O que você precisa
  1. Honeytone N-10 Mini Amp Speaker Replacement, Speaker: passo 1, imagem 1 %32 Honeytone N-10 Mini Amp Speaker Replacement, Speaker: passo 1, imagem 2 %32
    • Flip your amp over to begin removing the plastic cover.
  2. Honeytone N-10 Mini Amp Speaker Replacement: passo 2, imagem 1 %32 Honeytone N-10 Mini Amp Speaker Replacement: passo 2, imagem 2 %32
    • Remove the battery cover and take the battery out.
    • Unless you want a quick pick-me-up, in which case feel free to leave it in and get shocked.
  3. Honeytone N-10 Mini Amp Speaker Replacement: passo 3, imagem 1 %32 Honeytone N-10 Mini Amp Speaker Replacement: passo 3, imagem 2 %32
    • Unscrew the four corner screws using a phillips #0 screw driver to remove the back cover.
    • While the screws are recessed deep into the cover and difficult to see, 2-4 turns will easily release them.
  4. Honeytone N-10 Mini Amp Speaker Replacement: passo 4, imagem 1 %32 Honeytone N-10 Mini Amp Speaker Replacement: passo 4, imagem 2 %32 Honeytone N-10 Mini Amp Speaker Replacement: passo 4, imagem 3 %32
    • Remove the back cover by carefully pushing the battery connector through the hole in the cover.
  5. Honeytone N-10 Mini Amp Speaker Replacement: passo 5, imagem 1 %32 Honeytone N-10 Mini Amp Speaker Replacement: passo 5, imagem 2 %32 Honeytone N-10 Mini Amp Speaker Replacement: passo 5, imagem 3 %32
    • With the phillips #0 screwdriver, unscrew the two white plastic clips that hold the speaker in place.
  6. Honeytone N-10 Mini Amp Speaker Replacement: passo 6, imagem 1 %32 Honeytone N-10 Mini Amp Speaker Replacement: passo 6, imagem 2 %32
    • Use flush wire cutters to remove black and red wires from the old speaker.
    • Note: The black wire has already been removed in this example image.
  7. Honeytone N-10 Mini Amp Speaker Replacement: passo 7, imagem 1 %32 Honeytone N-10 Mini Amp Speaker Replacement: passo 7, imagem 2 %32 Honeytone N-10 Mini Amp Speaker Replacement: passo 7, imagem 3 %32
    • Connect the new speaker by soldering the black and red wires to the negative and positive connections respectively
  8. Honeytone N-10 Mini Amp Speaker Replacement: passo 8, imagem 1 %32
    • Connect the battery and turn the power on to test proper connection of the new speaker.
    • Some static is fine, this is the natural sound of the amp.
    • Careful not to touch any of the metal components inside while temporarily testing the connection.
  9. Honeytone N-10 Mini Amp Speaker Replacement: passo 9, imagem 1 %32
    • Reverse steps 1-5 to complete repair.
    • Connect the amp to your favorite instrument and test out the new sound!
Linha de Chegada
3 outras pessoas executaram este guia.
Corey Brown
Membro desde: 06/24/16
8.682 Reputação
Autoria de 11 guias
Um comentário
Cool. If mine doesn’t work, is it likely to be the speaker? Thanks.
hupaand - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 15
Duração total: 3,489
