Ir para o conteúdo principal
Honda Fit Reset Oil Life Indicator Replacement
      • Turn the key in the ignition to the run position (right before the start position)
      Pergunte ao FixBot
      Comentar
      • Press the SELECT/RESET knob repeatedly until the engine oil life indicator is displayed.
      Pergunte ao FixBot
      Comentar
      • Press and hold the SELECT/RESET knob for more than 10 seconds. The engine oil life indicator and the maintenance code(s) will blink.
      Pergunte ao FixBot
      Comentar
      • Press and hold the SELECT/RESET knob for more than 5 seconds. The maintenance items code(s) will disappear, and the engine oil life will reset to 100%.
      Pergunte ao FixBot
      Comentar
      • Turn the key in the ignition to the off position, and then start the engine to verify the indicator has been reset.
      Pergunte ao FixBot
      Comentar
Conclusão
You did it!
21 outras pessoas executaram este guia.
Jasen Friedle
Membro desde: 08/25/14
3.966 Reputação
Autoria de 3 guias
6Comentários do guia
Great. I did it—and I’m a girl!!
pthompso99 - Responder Compartilhar
Excellent! Glad to hear it.
Jasen Friedle - Responder Compartilhar
in my case i followed the step through. 100% oil life was achieved but when i turn the ignition off and turn it back on to verify, it goes back to 15%
Esosa Aghimien - Responder Compartilhar
And how can I start the car that it won't start
sbukataake - Responder Compartilhar
Have you tried changing your blinker fluid?
neegnorg - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 57
Últimos 30 dias: 305
Ao todo: 85,867
