Ir para o conteúdo principal
Honda 6500 Watt Generator EG6500CL AT Stator Replacement
O que você precisa
  1. Honda 6500 Watt Generator EG6500CL AT Stator Replacement, Honda 6500 Watt Generator EG6500CL AT Safety Precautions: passo 1, imagem 1 %32 Honda 6500 Watt Generator EG6500CL AT Stator Replacement, Honda 6500 Watt Generator EG6500CL AT Safety Precautions: passo 1, imagem 2 %32
    • Before you work on the device, make sure to switch the engine off.
    • Switch the circuit breaker off.
  2. Honda 6500 Watt Generator EG6500CL AT Stator Replacement, Disconnect the spark plug: passo 2, imagem 1 %32 Honda 6500 Watt Generator EG6500CL AT Stator Replacement, Disconnect the spark plug: passo 2, imagem 2 %32
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  3. Honda 6500 Watt Generator EG6500CL AT Stator Replacement: passo 3, imagem 1 %32 Honda 6500 Watt Generator EG6500CL AT Stator Replacement: passo 3, imagem 2 %32
    • Twist the fuel valve clockwise into the cutoff position.
  4. Honda 6500 Watt Generator EG6500CL AT Stator Replacement, Remove the generator cover: passo 4, imagem 1 %32
    • Use a Phillips screwdriver to remove the two screws securing the generator cover.
  5. Honda 6500 Watt Generator EG6500CL AT Stator Replacement: passo 5, imagem 1 %32 Honda 6500 Watt Generator EG6500CL AT Stator Replacement: passo 5, imagem 2 %32
    • Remove the generator cover.
  6. Honda 6500 Watt Generator EG6500CL AT Stator Replacement, Remove the brush assembly: passo 6, imagem 1 %32 Honda 6500 Watt Generator EG6500CL AT Stator Replacement, Remove the brush assembly: passo 6, imagem 2 %32
    • Squeeze and disconnect the stator connector from the wiring harness.
  7. Honda 6500 Watt Generator EG6500CL AT Stator Replacement: passo 7, imagem 1 %32 Honda 6500 Watt Generator EG6500CL AT Stator Replacement: passo 7, imagem 2 %32
    • Use a 10 mm socket to remove the bolt securing the brush assembly.
    • Pull the brush assembly out slightly from its recess.
  8. Honda 6500 Watt Generator EG6500CL AT Stator Replacement: passo 8, imagem 1 %32 Honda 6500 Watt Generator EG6500CL AT Stator Replacement: passo 8, imagem 2 %32
    • Disconnect the two spade connectors from the brush assembly.
  9. Honda 6500 Watt Generator EG6500CL AT Stator Replacement: passo 9, imagem 1 %32 Honda 6500 Watt Generator EG6500CL AT Stator Replacement: passo 9, imagem 2 %32
    • Remove the brush assembly.
    • During reassembly, use the second photo as reference for how to wire the brush assembly.
  10. Honda 6500 Watt Generator EG6500CL AT Stator Replacement, Loosen the rear generator housing: passo 10, imagem 1 %32
    • Use a 10 mm socket to remove the four long bolts securing the generator cover to the generator assembly.
    • During reassembly, tighten these bolts to 7 ft-lb (10 N-m).
  11. Honda 6500 Watt Generator EG6500CL AT Stator Replacement: passo 11, imagem 1 %32 Honda 6500 Watt Generator EG6500CL AT Stator Replacement: passo 11, imagem 2 %32
    • Use a 14 mm socket to remove the rotor bolt from the generator assembly.
    • This bolt may be difficult to loosen. If you have trouble removing the bolt, use an impact wrench or breaker bar.
    • During reassembly, tighten this bolt to 33 ft-lb (44 N-m).
  12. Honda 6500 Watt Generator EG6500CL AT Stator Replacement: passo 12, imagem 1 %32 Honda 6500 Watt Generator EG6500CL AT Stator Replacement: passo 12, imagem 2 %32
    • Remove the rotor bolt and washer.
  13. Honda 6500 Watt Generator EG6500CL AT Stator Replacement: passo 13, imagem 1 %32 Honda 6500 Watt Generator EG6500CL AT Stator Replacement: passo 13, imagem 2 %32 Honda 6500 Watt Generator EG6500CL AT Stator Replacement: passo 13, imagem 3 %32
    • Use an 8 mm socket to remove the four nuts securing the wiring harness to the terminal.
    • Remove only the top nut from each terminal post.
    • Be careful not to lose the crush washers behind them.
    • Remove the wiring harness wires from the terminal.
  14. Honda 6500 Watt Generator EG6500CL AT Stator Replacement, Reassembly tip: passo 14, imagem 1 %32 Honda 6500 Watt Generator EG6500CL AT Stator Replacement, Reassembly tip: passo 14, imagem 2 %32
    • During reassembly, use these photos as a reference for how to re-stack the terminal posts. From the terminal base to tip:
    • Base washer
    • Crush washer
    • Stator wire connector
    • Nut
    • Wiring harness connector
    • Crush washer
    • Nut
  15. Honda 6500 Watt Generator EG6500CL AT Stator Replacement: passo 15, imagem 1 %32 Honda 6500 Watt Generator EG6500CL AT Stator Replacement: passo 15, imagem 2 %32 Honda 6500 Watt Generator EG6500CL AT Stator Replacement: passo 15, imagem 3 %32
    • Use an 8 mm socket to remove the three bolts securing the wiring terminal and harness.
    • Remove the Phillips screw securing the harness ground.
    • Loosen the wiring terminal and harness from their resting positions.
  16. Honda 6500 Watt Generator EG6500CL AT Stator Replacement: passo 16, imagem 1 %32 Honda 6500 Watt Generator EG6500CL AT Stator Replacement: passo 16, imagem 2 %32
    • Use pliers to release the cable tie securing the wiring harness to the generator assembly.
  17. Honda 6500 Watt Generator EG6500CL AT Stator Replacement, Loosen the mounting bolts: passo 17, imagem 1 %32
    • Carefully tilt the rear of the generator upwards to access the under-frame bolts.
    • Use a 12 mm socket to remove the two bolts underneath the frame, which secures the rear generator housing.
  18. Honda 6500 Watt Generator EG6500CL AT Stator Replacement: passo 18, imagem 1 %32 Honda 6500 Watt Generator EG6500CL AT Stator Replacement: passo 18, imagem 2 %32 Honda 6500 Watt Generator EG6500CL AT Stator Replacement: passo 18, imagem 3 %32
    • Removing these nuts give the generator assembly enough slack to remove the rear bushings.
    • Use a 14 mm socket to remove the mounting nut next to the emissions canister.
    • Use a 14 mm socket to remove the mounting nut near the oil filler hole.
  19. Honda 6500 Watt Generator EG6500CL AT Stator Replacement: passo 19, imagem 1 %32 Honda 6500 Watt Generator EG6500CL AT Stator Replacement: passo 19, imagem 2 %32
    • Use a 14 mm socket to remove the two nuts securing the rear housing to the bushings.
    • During reassembly, be sure to re-attach the ground terminal to the left bushing.
  20. Honda 6500 Watt Generator EG6500CL AT Stator Replacement, Remove the rear bushings: passo 20, imagem 1 %32 Honda 6500 Watt Generator EG6500CL AT Stator Replacement, Remove the rear bushings: passo 20, imagem 2 %32 Honda 6500 Watt Generator EG6500CL AT Stator Replacement, Remove the rear bushings: passo 20, imagem 3 %32
    • In these photos, the generator frame is propped on some blocks for ease of access. You do not need to do this for the procedure.
    • Tilt the generator assembly by lifting the rear housing slightly.
    • Place support blocks underneath the silver generator housing to support the generator assembly.
    • The generator weight should rest on the support blocks and no longer on the rear bushings.
    • Do not support the generator by the black stator cover.
  21. Honda 6500 Watt Generator EG6500CL AT Stator Replacement: passo 21, imagem 1 %32 Honda 6500 Watt Generator EG6500CL AT Stator Replacement: passo 21, imagem 2 %32 Honda 6500 Watt Generator EG6500CL AT Stator Replacement: passo 21, imagem 3 %32
    • Lift the rear generator housing up as far as you can and maneuver the left bushing out of its socket.
    • Remove the left bushing.
  22. Honda 6500 Watt Generator EG6500CL AT Stator Replacement: passo 22, imagem 1 %32
    • Repeat the previous step to remove the right bushing from its socket.
  23. Honda 6500 Watt Generator EG6500CL AT Stator Replacement, Remove the rear generator housing: passo 23, imagem 1 %32 Honda 6500 Watt Generator EG6500CL AT Stator Replacement, Remove the rear generator housing: passo 23, imagem 2 %32
    • Remove the rear generator housing from the generator assembly.
  24. Honda 6500 Watt Generator EG6500CL AT Stator Replacement, Remove the stator cover: passo 24, imagem 1 %32 Honda 6500 Watt Generator EG6500CL AT Stator Replacement, Remove the stator cover: passo 24, imagem 2 %32
    • Rotate the stator cover so that the seam is at an accessible angle.
  25. Honda 6500 Watt Generator EG6500CL AT Stator Replacement: passo 25, imagem 1 %32 Honda 6500 Watt Generator EG6500CL AT Stator Replacement: passo 25, imagem 2 %32 Honda 6500 Watt Generator EG6500CL AT Stator Replacement: passo 25, imagem 3 %32
    • Use a flathead screwdriver to pry up the tabs holding the stator cover together.
  26. Honda 6500 Watt Generator EG6500CL AT Stator Replacement: passo 26, imagem 1 %32
    • Remove the stator cover.
  27. Honda 6500 Watt Generator EG6500CL AT Stator Replacement, Remove the stator: passo 27, imagem 1 %32 Honda 6500 Watt Generator EG6500CL AT Stator Replacement, Remove the stator: passo 27, imagem 2 %32 Honda 6500 Watt Generator EG6500CL AT Stator Replacement, Remove the stator: passo 27, imagem 3 %32
    • Remove the stator by pulling it straight out of the generator assembly.
  28. Honda 6500 Watt Generator EG6500CL AT Stator Replacement, Reassembly tip: passo 28, imagem 1 %32
    • During reassembly, you don't need to install the stator in a precise rotational position. Just make sure the stator cables wires are in the top-left corner.
Conclusão
Uma outra pessoa concluiu este guia.
Arthur Shi
Membro desde: 01/03/18
283.326 Reputação
Autoria de 587 guias
Equipe
iFixit Membro de iFixit
Staff
118 Membros
Autoria de 19.632 guias
2Comentários do guia
How to remove the armature from the flywheel
westcoaststyle3 - Responder
How to rewind the stator Generator ?
Taher Dawud - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 38
Ao todo: 2,112
