Introdução
This guide shows how to remove and replace the automatic voltage regulator module for the Honda 6500 Watt Generator EG6500CL AT.
O que você precisa
Before you work on the device, make sure to switch the engine off.
Switch the circuit breaker off.
Grab the plastic housing at the end of the spark plug wire.
Pull firmly to disconnect the wire from the spark plug.
Remove the five Phillips screws securing the front panel:
Two 35 mm screws
Two 20 mm screws
One 15 mm screw
Carefully slide and remove the automatic voltage regulator out of its recess.
