Ir para o conteúdo principal
Holmes HEH8031 Circuit Board Replacement
O que você precisa
  1. Holmes HEH8031 Circuit Board Replacement, Housing: passo 1, imagem 1 %32
    • Ensure the device is unplugged from the wall outlet.
  2. Holmes HEH8031 Circuit Board Replacement: passo 2, imagem 1 %32
    • Remove eight 12-mm Phillips #2 screws from the back cover.
  3. Holmes HEH8031 Circuit Board Replacement: passo 3, imagem 1 %32 Holmes HEH8031 Circuit Board Replacement: passo 3, imagem 2 %32
    • Turn heater over so the controls are facing up.
    • Lift the front housing away from the back of the fan and slowly fold the front housing back down to the floor.
    • Internal wires are connected to both halves of the housing. Be careful when separating the housing.
  4. Holmes HEH8031 Circuit Board Replacement, Circuit Board Removal: passo 4, imagem 1 %32
    • Remove four 12mm Phillips #2 screws from the circuit board.
  5. Holmes HEH8031 Circuit Board Replacement, Circuit Board: passo 5, imagem 1 %32 Holmes HEH8031 Circuit Board Replacement, Circuit Board: passo 5, imagem 2 %32 Holmes HEH8031 Circuit Board Replacement, Circuit Board: passo 5, imagem 3 %32
    • Desolder the BLACK wires from the "AC-L" point and "T/S" point.
    • Learn how to solder and desolder connections here!
    • Desolder the WHITE wire from the "AC-N" point.
    • Desolder the RED wire from the "FAN-RED".
    • Desolder the GREY wire from the "24V" point.
    • Desolder the BROWN wires from "HEAT1," and "HEAT2" points.
    • Be sure to use desoldering wick when you remove the wire connections.
  6. Holmes HEH8031 Circuit Board Replacement: passo 6, imagem 1 %32 Holmes HEH8031 Circuit Board Replacement: passo 6, imagem 2 %32
    • Desolder the WHITE connector (attached to the GRAY wire coming of the thermostat) from the "NTC101" point.
Conclusão
Uma outra pessoa concluiu este guia.
Chris Shaffer
Membro desde: 10/12/16
255 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 2-1, Baechle Fall 2016 Membro de IUPUI, Team 2-1, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G1
Membros da 4
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 973
