Ir para o conteúdo principal
Hitachi CP-X440 Lens Replacement
O que você precisa
  1. Hitachi CP-X440 Lens Replacement, Motherboard: passo 1, imagem 1 %32
    • Turn the projector upside down so the bottom is facing up.
    • Using a Phillips #1 screwdriver remove the six black 2 mm screws.
    • The screws are deep in the holes, so be careful when removing them as they can easily fall off the screwdriver tip.
    Pergunte ao FixBot
    Comentar
  2. Hitachi CP-X440 Lens Replacement: passo 2, imagem 1 %32 Hitachi CP-X440 Lens Replacement: passo 2, imagem 2 %32
    • Flip the projector right-side up and navigate to the back panel.
    • Remove the three black 10 mm screws on the back panel with a Phillips #1 screwdriver.
    • Remove the two silver 10 mm screws on the power switch panel with a Phillips #1 screwdriver.
    Pergunte ao FixBot
    Comentar
  3. Hitachi CP-X440 Lens Replacement: passo 3, imagem 1 %32 Hitachi CP-X440 Lens Replacement: passo 3, imagem 2 %32
    • Now turn the projector so the front is facing you.
    • Gently remove the lid from the bottom of the projector so the green circuit board is exposed.
    Pergunte ao FixBot
    Comentar
  4. Hitachi CP-X440 Lens Replacement: passo 4, imagem 1 %32 Hitachi CP-X440 Lens Replacement: passo 4, imagem 2 %32
    • Gently remove the cables from their white connectors on the circuit board.
    Pergunte ao FixBot
    Comentar
  5. Hitachi CP-X440 Lens Replacement: passo 5, imagem 1 %32
    • Gently pull out the three orange ribbons from their white connectors on the circuit board.
    • You can use a spudger tool to pry them out of place.
    Pergunte ao FixBot
    Comentar
  6. Hitachi CP-X440 Lens Replacement: passo 6, imagem 1 %32
    • Remove the five silver 5 mm screws on the circuit board with a Phillips #2 screwdriver.
    Pergunte ao FixBot
    Comentar
  7. Hitachi CP-X440 Lens Replacement: passo 7, imagem 1 %32
    • Remove the motherboard so the projector is exposed.
    Pergunte ao FixBot
    Comentar
  8. Hitachi CP-X440 Lens Replacement, Lens: passo 8, imagem 1 %32 Hitachi CP-X440 Lens Replacement, Lens: passo 8, imagem 2 %32 Hitachi CP-X440 Lens Replacement, Lens: passo 8, imagem 3 %32
    • As you look at the the device overhead, you will see three pieces of orange ribbon.
    • Attached to the orange ribbon will be a stabilizer over the lamp.
    • On each side, unscrew the two 1 cm screws with a Phillips #0 Screwdriver.
    • Then remove the piece holding the orange ribbons, called the stabilizer from this point on.
    Pergunte ao FixBot
    Comentar
  9. Hitachi CP-X440 Lens Replacement: passo 9, imagem 1 %32 Hitachi CP-X440 Lens Replacement: passo 9, imagem 2 %32 Hitachi CP-X440 Lens Replacement: passo 9, imagem 3 %32
    • Once the stabilizer is removed, set it to the side.
    • Use a Phillips #0 screwdriver to remove the two 1 cm screws on both sides of the lens.
    • The lens element should be easily lifted out of the device.
    Pergunte ao FixBot
    Comentar
  10. Hitachi CP-X440 Lens Replacement: passo 10, imagem 1 %32 Hitachi CP-X440 Lens Replacement: passo 10, imagem 2 %32
    • Once the lens element is safely removed, you will see 4 tiny 1/2 centimeter screws surrounding the lens.
    • Use a Phillips #000 screwdriver to unscrew each screw. This will allow you to easily remove the lens.
    Pergunte ao FixBot
    Comentar
  11. Hitachi CP-X440 Lens Replacement: passo 11, imagem 1 %32 Hitachi CP-X440 Lens Replacement: passo 11, imagem 2 %32 Hitachi CP-X440 Lens Replacement: passo 11, imagem 3 %32
    • Once the lens is safely removed, turn it face up.
    Pergunte ao FixBot
    Comentar
  12. Hitachi CP-X440 Lens Replacement: passo 12, imagem 1 %32 Hitachi CP-X440 Lens Replacement: passo 12, imagem 2 %32
    • Begin to gently unscrew the lens by hand, being mindful of light pressure.
    • After a few turns, the lens should be easily removed.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 31
Ao todo: 386
