Ir para o conteúdo principal
Hitachi CP-X2010N Lens Replacement
O que você precisa
  1. Hitachi CP-X2010N Lens Replacement, Top Panel: passo 1, imagem 1 %32 Hitachi CP-X2010N Lens Replacement, Top Panel: passo 1, imagem 2 %32 Hitachi CP-X2010N Lens Replacement, Top Panel: passo 1, imagem 3 %32
    • Flip the projector upside down to expose the screws on the underside.
    Pergunte ao FixBot
    Comentar
  2. Hitachi CP-X2010N Lens Replacement: passo 2, imagem 1 %32 Hitachi CP-X2010N Lens Replacement: passo 2, imagem 2 %32 Hitachi CP-X2010N Lens Replacement: passo 2, imagem 3 %32
    • Use a Phillips #2 screwdriver to remove eight black 14 mm screws holding the top panel to the main projector body.
    Pergunte ao FixBot
    Comentar
  3. Hitachi CP-X2010N Lens Replacement: passo 3, imagem 1 %32
    • Flip projector right side up and orient it so you are facing the rear panel.
    Pergunte ao FixBot
    Comentar
  4. Hitachi CP-X2010N Lens Replacement: passo 4, imagem 1 %32 Hitachi CP-X2010N Lens Replacement: passo 4, imagem 2 %32 Hitachi CP-X2010N Lens Replacement: passo 4, imagem 3 %32
    • Use a Phillips #2 screwdriver to remove two silver 22 mm long screws.
    • Use a Phillips #2 screwdriver to remove the short silver 10 mm screw.
    Pergunte ao FixBot
    Comentar
  5. Hitachi CP-X2010N Lens Replacement: passo 5, imagem 1 %32 Hitachi CP-X2010N Lens Replacement: passo 5, imagem 2 %32 Hitachi CP-X2010N Lens Replacement: passo 5, imagem 3 %32
    • Carefully lift the top panel from the body of the projector, making sure it doesn't catch on anything.
    • Remove the panel from the body of the projector.
    Pergunte ao FixBot
    Comentar
  6. Hitachi CP-X2010N Lens Replacement, Motherboard: passo 6, imagem 1 %32 Hitachi CP-X2010N Lens Replacement, Motherboard: passo 6, imagem 2 %32 Hitachi CP-X2010N Lens Replacement, Motherboard: passo 6, imagem 3 %32
    • Carefully pinch the edges of the two blue connectors and pull upwards to remove them from the motherboard.
    • Carefully pinch and remove the small gray connector next to the blue wire opposite the speakers.
    Pergunte ao FixBot
    Comentar
  7. Hitachi CP-X2010N Lens Replacement: passo 7, imagem 1 %32 Hitachi CP-X2010N Lens Replacement: passo 7, imagem 2 %32 Hitachi CP-X2010N Lens Replacement: passo 7, imagem 3 %32
    • Use a Phillips #2 screwdriver to remove the two black 14 mm screws securing the button array.
    • Move the wires for better access to the screws if needed.
    Pergunte ao FixBot
    Comentar
  8. Hitachi CP-X2010N Lens Replacement: passo 8, imagem 1 %32 Hitachi CP-X2010N Lens Replacement: passo 8, imagem 2 %32 Hitachi CP-X2010N Lens Replacement: passo 8, imagem 3 %32
    • Remove the bracket that was being held by the screw.
    • Take a picture or memorize its orientation for easier reinstallation.
    Pergunte ao FixBot
    Comentar
  9. Hitachi CP-X2010N Lens Replacement: passo 9, imagem 1 %32 Hitachi CP-X2010N Lens Replacement: passo 9, imagem 2 %32
    • Pull the button array and network adapter out carefully.
    • Make sure all the wires connected to the array are unplugged.
    Pergunte ao FixBot
    Comentar
  10. Hitachi CP-X2010N Lens Replacement: passo 10, imagem 1 %32 Hitachi CP-X2010N Lens Replacement: passo 10, imagem 2 %32
    • Use a Phillips #2 screwdriver to remove the silver 10 mm screw securing the ground wire.
    • Keep the screw and washer in an easily accessible place.
    Pergunte ao FixBot
    Comentar
  11. Hitachi CP-X2010N Lens Replacement: passo 11, imagem 1 %32
    • Use a Phillips #2 screwdriver to remove the black 14 mm screw securing the motherboard to the case.
    Pergunte ao FixBot
    Comentar
  12. Hitachi CP-X2010N Lens Replacement: passo 12, imagem 1 %32 Hitachi CP-X2010N Lens Replacement: passo 12, imagem 2 %32 Hitachi CP-X2010N Lens Replacement: passo 12, imagem 3 %32
    • Delicately pinch and pull off all the wired connections surrounding the outside of the motherboard.
    Pergunte ao FixBot
    Comentar
  13. Hitachi CP-X2010N Lens Replacement: passo 13, imagem 1 %32 Hitachi CP-X2010N Lens Replacement: passo 13, imagem 2 %32 Hitachi CP-X2010N Lens Replacement: passo 13, imagem 3 %32
    • Use the tip of a spudger or your fingernail to flip up the small locking flap on the three orange cable locks. Then, you can safely pull the cables out.
    • Too much force could break the ribbon cable.
    Pergunte ao FixBot
    Comentar
  14. Hitachi CP-X2010N Lens Replacement: passo 14, imagem 1 %32 Hitachi CP-X2010N Lens Replacement: passo 14, imagem 2 %32
    • Lift the motherboard out from the projector carefully so that it doesn't catch on any other components.
    Pergunte ao FixBot
    Comentar
  15. Hitachi CP-X2010N Lens Replacement, Lens: passo 15, imagem 1 %32 Hitachi CP-X2010N Lens Replacement, Lens: passo 15, imagem 2 %32 Hitachi CP-X2010N Lens Replacement, Lens: passo 15, imagem 3 %32
    • Use a Phillips #2 screwdriver to remove the three black 14 mm screws holding down the projector housing.
    Pergunte ao FixBot
    Comentar
  16. Hitachi CP-X2010N Lens Replacement: passo 16, imagem 1 %32 Hitachi CP-X2010N Lens Replacement: passo 16, imagem 2 %32
    • Loosen the three silver Phillips #2 screws that secure the lamp housing.
    • The screws are captive and do not need to be removed from the lamp housing.
    Pergunte ao FixBot
    Comentar
  17. Hitachi CP-X2010N Lens Replacement: passo 17, imagem 1 %32 Hitachi CP-X2010N Lens Replacement: passo 17, imagem 2 %32
    • Work the projector housing loose from the two pins on the lamp housing.
    Pergunte ao FixBot
    Comentar
  18. Hitachi CP-X2010N Lens Replacement: passo 18, imagem 1 %32 Hitachi CP-X2010N Lens Replacement: passo 18, imagem 2 %32 Hitachi CP-X2010N Lens Replacement: passo 18, imagem 3 %32
    • Lift the projector housing up from the left side and remove it from the case.
    Pergunte ao FixBot
    Comentar
  19. Hitachi CP-X2010N Lens Replacement: passo 19, imagem 1 %32 Hitachi CP-X2010N Lens Replacement: passo 19, imagem 2 %32 Hitachi CP-X2010N Lens Replacement: passo 19, imagem 3 %32
    • Turn the front lens element counterclockwise and lift it off the projector housing.
    • The front element will have lubricant on the inside shaft. Take care not to rub any of it off.
    Pergunte ao FixBot
    Comentar
  20. Hitachi CP-X2010N Lens Replacement: passo 20, imagem 1 %32 Hitachi CP-X2010N Lens Replacement: passo 20, imagem 2 %32 Hitachi CP-X2010N Lens Replacement: passo 20, imagem 3 %32
    • Inspect all glass elements for debris or damage.
    • Clean or replace the lens as needed.
    Pergunte ao FixBot
    Comentar
Conclusão
4 outras pessoas executaram este guia.
Chance Kidd
Membro desde: 09/20/22
1.184 Reputação
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 20
Ao todo: 388
