Ir para o conteúdo principal
Hisense Sero 8 Motherboard Replacement
O que você precisa
  1. Hisense Sero 8 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 Hisense Sero 8 Motherboard Replacement, Motherboard: passo 1, imagem 2 %32 Hisense Sero 8 Motherboard Replacement, Motherboard: passo 1, imagem 3 %32
    • Remove the back cover of the device using the plastic opening tool.
    • Pry open a corner of the device, then continue down the side with the tool to open the device.
  2. Hisense Sero 8 Motherboard Replacement: passo 2, imagem 1 %32 Hisense Sero 8 Motherboard Replacement: passo 2, imagem 2 %32
    • Remove the black tape located to the left of the device.
    • Remove the clear tape directly below the camera.
  3. Hisense Sero 8 Motherboard Replacement: passo 3, imagem 1 %32
    • Remove the seven 4.43mm screws located at the top of the device using the Phillips #00 screwdriver.
    • There is no need to remove the bottom two screws holding the speakers in place.
  4. Hisense Sero 8 Motherboard Replacement: passo 4, imagem 1 %32
    • Unlock the three ribbon cable connector latches to remove the cables.
  5. Hisense Sero 8 Motherboard Replacement: passo 5, imagem 1 %32 Hisense Sero 8 Motherboard Replacement: passo 5, imagem 2 %32 Hisense Sero 8 Motherboard Replacement: passo 5, imagem 3 %32
    • Be cautious of the extremely hot tip of the soldering iron.
    • Desolder the red, black, and yellow wires to remove the motherboard. Take a look at this guide to learn how to solder and desolder connections.
    • Desolder the black wire located on the top left of the device.
    • Once desoldered, carefully lift the motherboard out of the device.
Conclusão
Katharina
Membro desde: 02/23/15
506 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 1-2, Leahy Winter 2015 Membro de USF Tampa, Team 1-2, Leahy Winter 2015
USFT-LEAHY-W15S1G2
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 7
Duração total: 1,332
