Ir para o conteúdo principal
Hisense Chromebook C11 Hard Drive Replacement
O que você precisa
  1. Hisense Chromebook C11 Hard Drive Replacement, Back Panel: passo 1, imagem 1 %32
    • Remove the front two hub caps.
    • When finished, you should be able to remove the back cover.
  2. Hisense Chromebook C11 Hard Drive Replacement: passo 2, imagem 1 %32
    • Unscrew the screws with the Phillips #00 screwdriver.
  3. Hisense Chromebook C11 Hard Drive Replacement: passo 3, imagem 1 %32
    • Pry the perimeter of the case open with the plastic opening tool.
    • Remove the back panel.
  4. Hisense Chromebook C11 Hard Drive Replacement, Battery: passo 4, imagem 1 %32
    • Be careful not to puncture the battery with the screwdriver or any sharp instrument.
    • Unscrew the screws with the Phillips #000 screwdriver.
  5. Hisense Chromebook C11 Hard Drive Replacement: passo 5, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use the tweezers to unplug the battery.
  6. Hisense Chromebook C11 Hard Drive Replacement: passo 6, imagem 1 %32
    • Remove the battery.
  7. Hisense Chromebook C11 Hard Drive Replacement, Hard Drive: passo 7, imagem 1 %32 Hisense Chromebook C11 Hard Drive Replacement, Hard Drive: passo 7, imagem 2 %32
    • Unscrew all of the screws that you can access on the hard drive.
    • If you cannot reach the screw beneath the black strip, move on to the next step.
  8. Hisense Chromebook C11 Hard Drive Replacement: passo 8, imagem 1 %32 Hisense Chromebook C11 Hard Drive Replacement: passo 8, imagem 2 %32 Hisense Chromebook C11 Hard Drive Replacement: passo 8, imagem 3 %32
    Comprar
    • Remove the black strip using the tweezers.
  9. Hisense Chromebook C11 Hard Drive Replacement: passo 9, imagem 1 %32
    • Unscrew the screw beneath the black strip if you haven't done so already.
  10. Hisense Chromebook C11 Hard Drive Replacement: passo 10, imagem 1 %32 Hisense Chromebook C11 Hard Drive Replacement: passo 10, imagem 2 %32
    • Remove the ribbon with the tweezers.
  11. Hisense Chromebook C11 Hard Drive Replacement: passo 11, imagem 1 %32 Hisense Chromebook C11 Hard Drive Replacement: passo 11, imagem 2 %32
    • Using the tweezers, carefully remove the latches attaching the silver computer chip.
  12. Hisense Chromebook C11 Hard Drive Replacement: passo 12, imagem 1 %32 Hisense Chromebook C11 Hard Drive Replacement: passo 12, imagem 2 %32
    • Continue gently removing all remaining points of attachment.
  13. Hisense Chromebook C11 Hard Drive Replacement: passo 13, imagem 1 %32
    • Carefully remove the hard drive.
Conclusão
Uma outra pessoa concluiu este guia.
Chelsea Charles
Membro desde: 10/09/18
422 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team S1-G3, Leahy Fall 2018 Membro de USF Tampa, Team S1-G3, Leahy Fall 2018
USFT-LEAHY-F18S1G3
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 1,169
